Author Topic: Cylinder Head Gasket?  (Read 5862 times)
Offline MikeFGTI
« on: 26 January 2012, 15:12 »
Hi all
I have an 06' GTi with 80k on the clock. It gets 'well used' but i'm always careful to let it warm up/cool down and servicing is always kept up to date.
Last night i noticed mayo on the inside of the oil filler cap, so i immediately panicked about the head gasket. The thing is there is nothing else to suggest any problem - starts/drives fine, no white smoke out the back, coolant level fine, oil on dipstick seems fine....
Are there any other problems i should be considering other than the gasket? Any advice on what i should check/test would be greatly appreciated.
Thanks
Mike
Offline AlanD
  • MK5 2.0T 16v
Re: Cylinder Head Gasket?
« Reply #1 on: 26 January 2012, 15:19 »
Have you got a picture of it? Is there a lot?
Often condensation forms which causes there to be a bit of mayo around the lid (especially if you do short journeys).
Offline MikeFGTI
« Reply #2 on: 26 January 2012, 15:24 »
hi Alan,
Cheers for the reply.
I dont have a photo but will try and take one later.
There is a fairly light covering on both the underside of the filler cap and the 'neck'. To be fiar, i have been doing mainly short journeys recently, and presumably the build up of condensation is more likely in cold weather- its just i've had the car for 3 years and i've never noticed this happen before...
Offline barrym381
« Reply #3 on: 26 January 2012, 16:16 »
wipe it off an take it for a good run then take cap off an check it
Offline DJGTi
« Reply #4 on: 26 January 2012, 20:40 »
This is perfectly normal in cold weather and/or after repeated short runs.
Offline MikeFGTI
« Reply #5 on: 27 January 2012, 09:01 »
I wiped the oil off first thing this morning, did 5 miles to work and checked the filler cap when I got to work. There was mayo on the underside of the cap again -admittedly not as much, but surely if this was condensation, it would take some time to form once the engine is starting to cool down?
Offline Gene Hunt.
« Reply #6 on: 27 January 2012, 10:49 »
Most of us get this mate if you only do short journeys over the winter. If the coolant in the tank is still nice & clear don't worry about it.This weekend give the oil filler cap a good clean with a cloth & then give it the beans on a decent run. :wink:
Candy White ED35.
Offline MikeFGTI
« Reply #7 on: 27 January 2012, 11:43 »
ok cheers mate. I'll do that.
I did look at the coolant in the dark last night and (by torch light) it possibly looked a bit murky. I'll have another look in daylight.
Offline Snooze
« Reply #8 on: 27 January 2012, 18:44 »
Mine does the same as i do a lot of short journeys.  Only a small amout of mayo though.  When I do a couple of longer journeys it soon goes.
2015 Mk7 Golf Gti 3dr Manual, Carbon Steel Grey, Michelin PS4's
« Reply #9 on: 28 January 2012, 21:38 »
5 miles is nothing, clean it off and do around 15 and then see if it comes back.
