Author Topic: Replacing clutch  (Read 4391 times)
Offline scarr89
  • Mk4 Golf, DERV FTW!
Replacing clutch
« on: 25 January 2012, 20:24 »
If I were to replace the clutch friction plate and pressure plate, would I need to replace the DMF and the release bearing at the same time? Or would it be ideal to replace these at the same time. May of come across a 2nd hand, almost brand new uprated sachs clutch but only pressure plate and friction plate...
Also, could it be done on a driveway? Any special tools required? (150PD 6 speed BTW)
Thanks  :smiley:
Offline Steve_PD
Re: Replacing clutch
« Reply #1 on: 25 January 2012, 20:58 »
Change the release bearing as well as its only £40. Flywheel generally gets done because its a pig of a job/expensive to do it twice.
You need two people as the gearbox is f**king heavy and its got to come out and go back in at almost 45 degrees.
Cant remember off the top of my head what tools we used. only special tool was a clutch aligner.
Total time was 5 hours including a service and bleeding the clutch. would have be quicker if we didn't get the gear box jammed trying to get it out...
Offline mercedes190d
« Reply #2 on: 03 February 2012, 06:18 »
as mentioned you will need 2 people as awkward if you do it on the drive which is possible,
but you need to get the car really high off the floor to get 2 people under and the box on the 45 degrees
just usual tools and aligner
Offline sprout99
« Reply #3 on: 03 February 2012, 08:28 »
Thanks  :smiley:
i have an unused sachs oem spec friction plate going spare  - you can buy an uprated cover from clutch specialists in Leeds for £75 !!
I got my kevlar drive plate from there for £60 delivered. (so you could have a kevlar uprated clutch for less than £150 delivered)
fitting is something i thought about doing but last one cost me £120 cash to be changed over.
25th Anniversary TDi - PD
Oak green mk2
V50 D5 Sportwagon
Offline scarr89
« Reply #4 on: 03 February 2012, 09:23 »
Thanks alot mate...I'll bear that in mind!
Offline sprout99
« Reply #5 on: 03 February 2012, 09:47 »
only down side is that it's taken 1300 miles to bed in
Oak green mk2
V50 D5 Sportwagon
Offline scarr89
« Reply #6 on: 03 February 2012, 11:05 »
I read your post about it...
http://www.ebay.co.uk/itm/280811737570?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649#ht_1857wt_1270
I was looking this you see...But you say you have a 'Friction' plate. I am guessing that people call the different parts of the clutch by different names, as there is only a 'Pressure' plate in that ebay ad, is that the same as a 'Friction' plate? Then I'd just need the uprated 'Cover' (the thing with the spring fingers on it) and a new flywheel and release bearing if I were to purchase yours right?
Got this link for this place in Leeds mate?  :smiley:
Thankssssss
Offline sprout99
« Reply #7 on: 03 February 2012, 22:00 »
http://www.clutch-specialists.co.uk/
clutch is made up of three parts - Flywheel, Drive plate (friction plate) and cover (pressure plate) which has the sprung fingers
It's best to change the slave too.
Oak green mk2
V50 D5 Sportwagon
Offline sprout99
« Reply #8 on: 03 February 2012, 22:03 »
if you wanted my OEM sachs drive plate you could buy uprated cover from the people in Leeds
then a slave is about £40 too.
Flywheel is the risky bit....mines been done last september
Oak green mk2
V50 D5 Sportwagon
