Author Topic: PCV simplification and catch can fitting is this guide good for AUQ anni  (Read 2908 times)
Offline rench
will this guide be ok for me to follow or not on a auq
http://uk-mkivs.net/forums/p/269734/1771730.aspx
if not any other guides
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
Yes that's the guide most people (including myself) have followed and it's spot on :afro:
Offline rench
think ive got my head round it all now, how long did it take you to do?
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
spent a good couple of hours on it, mainly getting the elbow out of the oil filter housing as there's not much room down there
Mine was a bit easier being an AGU though
jockgti
if your taking inlet mani off best to get a new gasket,and take your time as not to drop the screws from mani
Offline golf-sib
  • Турботазик
Best tool for that is a telescopic magnet, £1 at poundland, make getting dropped things out the engine so easy and aligning bolts etc in places where your hands prove fiddly.
VW Golf - k03 AGU - 200BHP
1.8T AGU..
R135
  24
Offline daz veedub
  • Operation 1.8t bolf
have u managed to sort it now mate  :smiley:
Offline rench
going to tackle it at weekend hopefully
Offline Scott D
I used that guide for a AUQ and think the only difference is that two outlets on the inlet manifold need blocking off - might be included in the guide but seem to remember finding out about the inlet on another guide found on a seat site.
Would recommend renewing the elbow pipe that goes on the oil filter as well, I found it was well worn out and not securing properly.
2003 1.8T GTI 180 - APR Stage I, S2000 Filter, R-Tech Supersize TIP, Bilstein B12 Suspension, 18" OZ Superleggera, Recaro Heated Leathers, US Spec Rear Lights, N249/SAI/PCV Delete
1.8T AUQ - 241bhp & 286 ft-lb
R-Tech Map, Forge FMIC, SFS Oversized TIP, Ported Manifold, Milltek Turboback non res exhaust, Forge 007p, N249 & N112 delete, SAI delete, S2000 Air Filter, Sachs clutch & Lightweight Flywheel
