Author Topic: O2 sensor...  (Read 773 times)
Offline myles841
O2 sensor...
« on: 24 January 2012, 18:29 »
Hi all,
I have a slight issue with my car.... Ive plugged a code reader in and im getting o2 sensor failure which is fine i can replace this. My question is would this cause my car to run lumpy on idle and sometimes when stopping can idle at low rpm?
Offline damien010685
Re: O2 sensor...
« Reply #1 on: 24 January 2012, 22:19 »
I ran with mine coming up for a mth or so and never had issues like that bud
Offline Chris#101
Re: O2 sensor...
« Reply #2 on: 24 January 2012, 22:24 »
hat code got thrown up out of curiousity!?
as my emmision light keeps on flashing up after deleting it with a code reader!!
Im runnning a 3" turbo back non res exhaust  :huh:
          2003 1.8T: R-tech Live Cutom Stage 2 remap: N249 Bypass : Forge T.I.P : Forge 007p  : Forge Actuator, yellow spring : Toyosports F.M.I.C : Toyosports C.A.I :        PCV simplified - oil catch can : 42' Draft 3" turbo back non res exhaust system : Devils own W.M.I : 231bhp & 258lbs-ft
Offline myles841
Re: O2 sensor...
« Reply #3 on: 24 January 2012, 23:14 »
well i have a P0141 coming up on scanner? to do with the sensor after the cat? I think tbh the throttle body and air filter need changing/cleaning. I presume the throttle runs on a cable so could it be it needs tweaking to idle higher? seems to dip to about 400-500 rpm and sit there sometimes. It usually shoots down when i dip the clutch coming to a junction. Also thermostat needs changing so whether the colder reading could be confusing the ecu i dunno?  :undecided: cheers
