Author Topic: Brakes  (Read 1550 times)
Offline jonesltd
  • MK7 R
Brakes
« on: 24 January 2012, 13:13 »
Minor issue....about to order brakes and its given me 2 options for both rear and front....I have never changed them and dont know if I should go for 288 or 312? What came with the car orginally? I cannot afford to start changing things...
And a rough quote to change pads and discs for 1.9 52 reg 130?
Plus what brand? am on eurocarparts and got loads? eicher?
If you cant find it......Grind it
Offline jonnyturbo
Re: Brakes
« Reply #1 on: 24 January 2012, 13:20 »
312mm won't fit the gti as standard unless u have a anniversary model .
Offline km
Re: Brakes
« Reply #2 on: 24 January 2012, 13:21 »
so you're buying new pads and disc? a 130 will have 288 as standard
you need to order carriers to run 312
http://www.golfgtiforum.co.uk/index.php?topic=87778.0
Offline jonesltd
  • MK7 R
Re: Brakes
« Reply #3 on: 24 January 2012, 13:29 »
Great cheers! 288 are cheaper :)
Looking at 164 for the lot? That right 288 fronts and I think 256 rears or something?
« Last Edit: 24 January 2012, 14:06 by jonesltd »
Offline richw911
Re: Brakes
« Reply #4 on: 24 January 2012, 14:08 »
You wont have 256 rears  :wink:
Offline jonesltd
  • MK7 R
Re: Brakes
« Reply #5 on: 24 January 2012, 14:19 »
Another fail on my behalf LOL!
So far I have added up 164 though is that too much or too little? On ebay u can get a grooved/drilled set with pads for 140 etc?
Re: Brakes
« Reply #6 on: 24 January 2012, 15:15 »
I would avoid drilled and grooved discs, they tend to crack.
Offline topher
  • Administrator
  • fully functioning
Re: Brakes
« Reply #7 on: 24 January 2012, 16:34 »
do you really need discs and pads? i'm sure the discs were in pretty good condition last time i saw your car
Offline Toby
  • Car - less
Re: Brakes
« Reply #8 on: 24 January 2012, 19:26 »
Dont forget the eurocarparts 25% disc aldo.
312mm upgrade is worth while.
Currently down under
Offline jonesltd
  • MK7 R
Re: Brakes
« Reply #9 on: 25 January 2012, 09:07 »
Car has now done 135k I got the car when it had done 65k in 07 and never changed any of the brakes....
