Author Topic: smokey exhaust/failed emissions  (Read 2941 times)
Offline birch
« on: 19 January 2012, 20:14 »
my 1993 8v gti 2e has started smoking badly from the exhaust, the hotter the engine gets the more smokey it gets, its greyish smoke and smells quite strong. any advice would be appreciated! thanks.
« Last Edit: 01 February 2012, 09:58 by birch »
VW BUSH
Re: smokey exhaust
« Reply #1 on: 19 January 2012, 20:38 »
If its burning oil it could be valve seals or Rings.
Or it could be the head....
Does it over heat?
Is the oil/water full of Mayo?
Does it run ok?
Does it sound tappety?
 :smiley:
Offline birch
Re: smokey exhaust
« Reply #2 on: 19 January 2012, 21:01 »
no it doesnt overheat
it drives like normal
theres no mayo in the oil
it been a little tappety for years and is no worse now than before
VW BUSH
Re: smokey exhaust
« Reply #3 on: 19 January 2012, 21:08 »
Im on valve seals then :wink:
Offline birch
Re: smokey exhaust
« Reply #4 on: 19 January 2012, 21:21 »
thanks mate, is it a big job, what should i be looking to pay for the job to be done at my local mechanics?
VW BUSH
Re: smokey exhaust
« Reply #5 on: 19 January 2012, 22:47 »
That's just my guess, you need to check things like compression/cooling etc to be sure on the fault.
At a garage if you supplied a recon head and all the bits you are looking at around £200, and £200 in parts.
A good engine could be had for around £200 and a bit more to fit :smiley:
Re: smokey exhaust
« Reply #6 on: 20 January 2012, 10:48 »
Grey smoke is mixture / not running right, oil being burnt is blue so do the basics like check air filter and plugs,
VW BUSH
Re: smokey exhaust
« Reply #7 on: 20 January 2012, 13:59 »
Really the op needs to tell us what it smells of,  also given it runs well I would not jump to mixture being the fault.
I stand to be corrected though, maybe a picture of the smoke would help in diagnosis :smiley:
Re: smokey exhaust
« Reply #8 on: 20 January 2012, 14:08 »
Indeed but smoke does not always mean oil being burnt even more so when it is grey.
VW BUSH
Re: smokey exhaust
« Reply #9 on: 20 January 2012, 14:28 »
Quite right, grey/white smoke can indicate head faults or major overfueling but the op said it was running ok.
The pitfalls of internet diagnosis..........
