Author Topic: Re-spraying wheel arches and sill  (Read 3144 times)
Offline Chris_D
  • www.hijackbristol.co.uk
« on: 16 May 2005, 20:05 »
I need to re-spray my wheel arches and sills, also black part of both front and rear bumper, does it all come off easily enough, any tips/advice/pics would be greatly appreciated.
Chris
Offline Mr Blue
Re: Re-spraying wheel arches and sill
« Reply #1 on: 16 May 2005, 21:11 »
are you smoothing them?
unscrew the front bumper using a 17mm (think its 17?) socket. 4 in total.
rear bumper has another 4 and a few screws holding it on at the edges.
drill out all the rivets on the arches and discover rust. now they should come off  :smiley:
Think you have to unclip the sills but not sure how
Offline ...joe
« Reply #2 on: 16 May 2005, 21:28 »
^^^ what he said but tbe carefulkl with the side skirts as they break easily!!! yeah are you smmothing/painting them?
mail@trimdeluxe.co.uk
www.facebook.com/Trimdeluxe
Offline Chris_D
« Reply #3 on: 16 May 2005, 21:48 »
what does smoothing them involve? advantages?
Offline ...joe
« Reply #4 on: 16 May 2005, 22:56 »
it envolves smoothing all the little bumps off so they are like the rest of your bodywork, advantages are they look cool!!
Offline Chris_D
« Reply #5 on: 17 May 2005, 16:56 »
sounds like quite a few hours work, may give it a go though whilst there off, whats best to use for spraying them with then? a general black can of spray or back to black? can they be laquered to protect the paint or will they then come up shiny?
Offline Mr Blue
« Reply #6 on: 17 May 2005, 17:34 »
I would leave all the spraying/sanding down to a bodyshop if they give a right price. Spray them gloss black or something.
Sand smooth (if you want), plastic primer, then lots of black paint coats then lots of top coats
If you just spray it with a black paint can then it would flake off after a few days and would be a waste fo time
Offline Chris_D
« Reply #7 on: 17 May 2005, 19:01 »
you may have guessed i'm a complete novice at this, how easy will the black parts of the front and rear bumpers be to do? do tey come off the bumper or will they need to be masked off? Am i gonna need a new bbi bumper clip set or should they all go back on ok?
Offline Mr Blue
« Reply #8 on: 17 May 2005, 19:33 »
Once you have un-done the 4 bolts under the car the bumper should slide towards you. Wont need new bumper clips mate.
You have to mask off the coloured area of the bumper as its one piece. The bottom front splitter comes off  :smiley:
