Author Topic: XDS Setting  (Read 4140 times)
Offline KennyGTI
XDS Setting
« on: 19 January 2012, 16:16 »
Going to change mine this weekend.
http://www.golfmk6.com/forums/showthread.php?t=25039
 :smiley:
APR Stage 2+
Offline mkviken
Re: XDS Setting
« Reply #1 on: 19 January 2012, 17:36 »
did mine last week. i had a thread about it on here somewhere
it makes its turn a lot shaper and hold a tighter line in the gas but if its slippery you do get a bit more wheel hop/axle tramp whatever you want to call it
i would say in the dry or wet its much better but when its cold and slippery its better on 0.
Golf GTI 7.5 230 white silver
Offline KennyGTI
Re: XDS Setting
« Reply #2 on: 19 January 2012, 21:55 »
So you just changed your XDS to 2 and nothing else? Gonna give it a try and see if I notice a difference.  :nerd:
APR Stage 2+
Offline ScottA
Re: XDS Setting
« Reply #3 on: 19 January 2012, 22:46 »
What about 1, might be a good all round compromise?
Offline mkviken
Re: XDS Setting
« Reply #4 on: 20 January 2012, 09:41 »
no 1 is weak, 0 is normal and 2 is strong
its stupid the way they have it set out but 1 is actually weaker than 0 strangely
i have mine set to 2 and its very good. it makes the car a lot more responsive and better in and out of tight corners. ilk i said though if its very slippery i preferred 0 setting as it broke away/ASR came in more progressively
i didn't alter the brake assist. i find when your pushing on and the brakes are warm they're fine on factory setting but agree around the doors, under slow driving the pedal does have a bit of travel but i suppose it depends on how you use the car. for me the brakes in standard assist setting are good.
Offline Hurdy
Re: XDS Setting
« Reply #5 on: 02 February 2012, 18:39 »
Changed mine too......works on the Polo GTI too. :cool:
Seat Leon Cupra Black 290 DSG
Offline mkviken
Re: XDS Setting
« Reply #6 on: 02 February 2012, 18:59 »
I want to try setting 2 on the brake assist as I'm not impressed at all with pedal feel. Don't know if it would be over sensitive but I find the pedal has too much travel
Offline jdjd
Re: XDS Setting
« Reply #7 on: 03 February 2012, 00:09 »
Vagcom setting? Will it work on the R? And do you want to change mine hurdy :) :drool:
Offline mkviken
Re: XDS Setting
« Reply #8 on: 03 February 2012, 16:57 »
don't think the golf R has got the XDS but the scirocco R has, which is already in setting 2
you can change the brake assist though i would have thought
Offline KennyGTI
Re: XDS Setting
« Reply #9 on: 03 February 2012, 17:00 »
You can definitley notice the difference! Am delighted with the vagcom tweak :-)
APR Stage 2+
