Author Topic: RCD510 USB Stick  (Read 6551 times)
Offline ScottA
RCD510 USB Stick
« on: 18 January 2012, 22:38 »
Hi,
Could someone please confirm how the RCD510 shows songs which are stored on a USB stick? Does it show the file name or does it get the track details from the ID3 tags within the MP3? Can you navigate to different folders, for example could I create a folder "New Songs" and navigate to that?
Just sorting out my music now for when the car arrives lol. Anything I should be aware of when using USB?
Thanks,
Scott
Offline ajmoir36
Re: RCD510 USB Stick
« Reply #1 on: 18 January 2012, 22:48 »
You can create folders and it does use the tags. There are some limits like Max 1000 files per folder. If you want to mix all folders and all songs you need one in the root.
Diagonally parked in a parallel universe.
On Order: Mk8 R, Pure White, Reversing Camera, Harmon Kardon, Heated seats all round.
Gone: Mk7.5 R, 5dr, DSG, Deep Pearl Black, 18” Cadiz, Nav, Winter Pack, Keyless, Dynaudio and Reversing camera.
Gone: Mk7 R, 5dr, DSG, Limestone Grey, 19" Pretoria's, Nav Pro, DCC, Winter Pack, Keyless, Mobile Prep and Reversing Camera.
Gone: Mk6 GTD, 5dr, Manual, Tornado Red, 18" Vancouvers, RCD510 + Dynaudio, heated seats.
Offline ScottA
« Reply #2 on: 18 January 2012, 22:49 »
Cheers!
Offline PenguinGTI
« Reply #3 on: 18 January 2012, 23:01 »
Yep, just to confirm it's tags. You can look through the file info manually (to show artist, album etc) but by default it's tags.  :smiley:
Offline Keithuk
« Reply #4 on: 19 January 2012, 01:13 »
My RCD310 uses the ID3 tag of the MP3 when it displays the track info?
The handbook says you can make a play list with Windows media player and put that on the root of the USB stick. I've played them with and without the play list and its still the same, mine is always set on Mix All.
2010 Golf GTD (170) CBBB, 5 Door, Shadow Blue (P6/D5Q), Flat Tyre Indicator, Basic Protection Pack + VCDS.
Offline mkviken
« Reply #5 on: 08 March 2012, 20:14 »
does anyone know how to play albums bought on iTunes on a memory stick?
just made a 16gb usb stick and rcd510 says it can't play the purchased songs. all the mp3s from cps etc are fine
thanks
Golf GTI 7.5 230 white silver
Offline Nutkins
« Reply #6 on: 08 March 2012, 20:48 »
Anyone tried with Wav files? Does it display the file name?
Offline p3asa
« Reply #7 on: 08 March 2012, 21:13 »
I don't know if WAV can be played.
From the manual: Audio data in MP3, WMA, OGG Vorbis and AAC format from the
external data sticker, connected to the multimedia socket, can be
played via the radio.
Offline mkviken
« Reply #8 on: 09 March 2012, 18:39 »
worked out how to sort this iTunes not playing on the rcd510 i think
you need to convert them to mp3 by making a duplicate. you need to change from AAC or m4a to mp3 in the iTunes settings. the rcd510 won't play iTunes files.
if the file is m4a it can be converted but if its m4p its locked. means most of the music i legally bought can't be transferred to a usb stick.
Offline andyr
« Reply #9 on: 10 March 2012, 09:04 »
Google 'M4p to MP3 converters', there appears to be several out there that may work OK??
And the imminent overhauling of the copyright laws should make DRM a thing of the past (hopefully!)
http://www.telegraph.co.uk/technology/news/8678543/Copyright-law-overhaul-will-allow-fans-to-copy-music-to-iPods.html
Mk VI Black Pearl GTD.... No Frills, replaced a Black Pearl PD150 Bora, which in turn replaced a Dragon Green VR6 which followed a Dusty Mauve MK III 8v Gti.
