Author Topic: No grounding point on the back of head unit (Pioneer KEH-M7000RDS)  (Read 2008 times)
Offline Hongkongphooey
I've been experiencing a recurring problem with my head unit cutting out at random times.
Having got the removal keys and taken a closer look behind the head unit I've discovered there's no grounding rubber/screw on the back  :huh:
A few questions therefore:
(1) Where can I get a rubber/screw to make a connection to the ground wire on the back of the head unit?
(2) Will there be a wire somewhere (other the cables I can identify; those in the ISO loom, the antenna, the CD changer) that is the ground wire? What will this look like?
(3) Should I just pick up a cheap replacement head unit on Fleabay that has the grounding connection on?
All help appreciated...this is driving me nuts
« Last Edit: 18 January 2012, 21:23 by Hongkongphooey »
Maybe I should ask this question differently....do all Head Units have a grounding wire connection on the back or is this somehow integrated into the ISO loom?
Quite a few on EBay don't seem to have a dedicated grounding point on the back from the pics I've seen.
Ta
Answering my own question here but hopefully this will help others.
It appears on these old Pioneer HUs the Ground Wire goes into the ISO plug so no need for a separate ground connection on the back of the HU.
