Author Topic: Are Calibra Yellows required on an AUM? (Chris/Nick?)  (Read 3421 times)
Offline Yohan
Morning,
Have noticed R-Tech can make good power on the K03s units by replacing the weak actuators with a Forge item.
I know Chris used a Forge actuator and Calibra Yellow injectors on his AGU but am I correct in saying that the stock AUM injectors flow similar numbers to the Calibra Yellow's and therefore all I would need would be the Forge actuator?
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
Re: Are Calibra Yellows required on an AUM? (Chris/Nick?)
« Reply #1 on: 17 January 2012, 12:21 »
You got it, plus they won't fit lol
Offline jonnyturbo
« Reply #2 on: 17 January 2012, 13:31 »
Standard aum injectors are pretty gud tbh . And tbh unless you want to go bigger turbo the aum injectors are up to the job
Offline Yohan
« Reply #3 on: 17 January 2012, 13:34 »
Cheers guys :)
Offline Chris.
« Reply #4 on: 17 January 2012, 16:15 »
As above.  Ive read posts that say AUM injectors are good for 265bhp....but dont quote me on it without seeing facts.
Click For Build Thread
Offline Yohan
« Reply #5 on: 17 January 2012, 16:29 »
Thanks mate.
Offline Scott D
« Reply #6 on: 17 January 2012, 17:16 »
What sort of power and torque are AUMs making with the Forge actuator?
240bhp/260ft-lb ish?
2003 1.8T GTI 180 - APR Stage I, S2000 Filter, R-Tech Supersize TIP, Bilstein B12 Suspension, 18" OZ Superleggera, Recaro Heated Leathers, US Spec Rear Lights, N249/SAI/PCV Delete
1.8T AUQ - 241bhp & 286 ft-lb
R-Tech Map, Forge FMIC, SFS Oversized TIP, Ported Manifold, Milltek Turboback non res exhaust, Forge 007p, N249 & N112 delete, SAI delete, S2000 Air Filter, Sachs clutch & Lightweight Flywheel
Offline Chris.
« Reply #7 on: 17 January 2012, 17:21 »
All depends on the map at the end of the day.
Actuator will allow you to see over ~235bhp and hold boost a lot better to redline!
Offline bobbieboy69er
  • MK4 1.8T AUM
« Reply #8 on: 17 January 2012, 17:28 »
^^ if thats the case.  Would it have to be mapped in??
MK4 1.8T AUM|30mm Eibach Springs|Milltek cat back|4mo rear valance|pipercross filter|R-tech Stage 1 Remap|Baileys DV|Powerflex Front and Rear Bushes|312mm Front Brakes|Creation Motorsport TIP and hoses|17" TT Ronals|  220BHP
Offline Chris.
« Reply #9 on: 17 January 2012, 17:35 »
Ideally yes, especially if you are mapped already.
Your boost, timing and everything else altered in a remap will be adjusted to get the best from the OEM setup, and if it was weak, then you might be seeing more/higher readings than what you mean to.
An example MAY be:  Having fuelling adjusted to say 12psi boost at 4000-6000rpm and you are able to hold 14-15psi boost between the same range, thus you might end up running lean.
Heres a plot of a forge actuator put on and ran back to back without mods from R-tech.....speaks for itself!
« Last Edit: 17 January 2012, 17:37 by Chris. »
