Author Topic: Are Calibra Yellows required on an AUM? (Chris/Nick?)  (Read 3422 times)
Offline Chris#101
Re: Are Calibra Yellows required on an AUM? (Chris/Nick?)
« Reply #10 on: 17 January 2012, 20:35 »
whilst this subject is up can anyone think of anything else that I need to get the best overall figures for my stage2 custom remap!?
so far I have
car '03 auq 180
FMIC
Forge actuator yellow spring
3" turbo back non res system
007p
cai
forge tip
should I uprate fuelpump, injectors, maf!? if so to what
emailed and pmd r-tech several times over the past 3-4months but havent heard a peep which is where I plan on having the remap  :undecided:
cheers
          2003 1.8T: R-tech Live Cutom Stage 2 remap: N249 Bypass : Forge T.I.P : Forge 007p  : Forge Actuator, yellow spring : Toyosports F.M.I.C : Toyosports C.A.I :        PCV simplified - oil catch can : 42' Draft 3" turbo back non res exhaust system : Devils own W.M.I : 231bhp & 258lbs-ft
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #11 on: 17 January 2012, 20:45 »
phone Nick mate, I know he's very busy at the mo  :smiley:
Offline golf-sib
  • Турботазик
« Reply #12 on: 17 January 2012, 22:37 »
K03s with forge actuators clamped like a mofo will see 240~260max, you are looking at 240 figures though as the 260 was a race only map with race fuel, so don't dream of this number  :laugh:
VW Golf - k03 AGU - 200BHP
1.8T AGU..
R135
  24
Offline Chris#101
« Reply #13 on: 17 January 2012, 22:47 »
Is this in response to my current spec without pump maf injectors? :cool:
Offline Darksider1.8T
« Reply #14 on: 17 January 2012, 22:51 »
if think you'd have to upgrade the fuel pump
Offline golf-sib
  • Турботазик
« Reply #15 on: 17 January 2012, 23:35 »
Not to sure where you stand as I don't tune, I know on a AGU, MAF and Injectors max out around 236bhp at around 12.6:1. Where the AUM limit lies I wouldn't be able to advise, if I knew where the g/s of stock MAF maxed out it could help in determining if the MAF would be maxed out or not. Plus I have no idea where the pump maxes out.
Best thing is give a garage a call as they will know the natural limits of different components from the R&D of writing maps and they will be able to advise you.
But if the case is that the MAF, injectors and pump need upgrading I'd look into not bothering with a k03s forge actuator but a different turbo such as the t3/4 for the hassle of the minor power gain. With T3/4 you will see more power all the way through and the copies are proving cheap and reliable for £270, thats the money you would make from selling k03s and not buying a forge actuator... have a think about it depending on the outcome of upgraded components  :wink:
1.8T AGU..
R135
  24
Offline Chris.
« Reply #16 on: 18 January 2012, 00:52 »
£270 for turbo then you need a manifold (£100) custom downpipe £££ and boost pipework.
K03s and actuator make for a very quick daily car IMHO, thats not pushed over the top and still driveable. 250bhp just goes down with eagle F1 tyres up front.
Click For Build Thread
Offline golf-sib
  • Турботазик
« Reply #17 on: 18 January 2012, 09:39 »
£270 is with manifolds, then it will be a case of fabricating a TIP and using a reducer to latch onto the turbo and current pipework. Not sure on downpipe, need to check this out.
1.8T AGU..
R135
  24
Offline Chris.
« Reply #18 on: 18 January 2012, 12:59 »
As far as I know there isnt a on the market jobby thats 'cheap' to buy.  Having to find somoene good enough to do the work to a good standard is the hard part :(
Offline golf-sib
  • Турботазик
« Reply #19 on: 18 January 2012, 13:08 »
Do the work yourself, especially when you can get loads of ally pipe in kits nowdays with silicone joints and good clamps and the mk4's plumbing is nothing complicated, once you have done it you have done it. Only tool you will need is a beading tool.
1.8T AGU..
R135
  24
