Author Topic: suggestions for a performance exhaust for mk4 gti  (Read 2542 times)
Offline beststellalady
« on: 16 January 2012, 13:52 »
I am new to the vw world, i have a mk4 1.8 gti and it has a stainless steel back box on it at the mo which is quite loud, which in itself is fine but the car keeps wanting to stall all the time, when its not being reved, pls can anyone suggest what i should do or should i replace it?, if so what can i replace it with? thanks in advance
Offline daz veedub
  • Operation 1.8t bolf
Re: suggestions for a performance exhaust for mk4 gti
« Reply #1 on: 16 January 2012, 14:45 »
exhaust wont be causing it to stall
run a faultcode reader for faults
http://www.golfgtiforum.co.uk/index.php?topic=34420.0
also worth throttle bodie clean
http://www.golfgtiforum.co.uk/index.php?topic=87783.0
also check boost pipes for splits and leaks, could also be a faulty maf
http://www.golfgtiforum.co.uk/index.php?topic=94783.0
Offline bobbieboy69er
  • MK4 1.8T AUM
« Reply #2 on: 16 January 2012, 20:01 »
Welcome to hell  :evil:
try coils aswel.
MK4 1.8T AUM|30mm Eibach Springs|Milltek cat back|4mo rear valance|pipercross filter|R-tech Stage 1 Remap|Baileys DV|Powerflex Front and Rear Bushes|312mm Front Brakes|Creation Motorsport TIP and hoses|17" TT Ronals|  220BHP
Offline Rhyso
« Reply #3 on: 16 January 2012, 20:09 »
As you're in Cardiff go to ProSpeed - you won't find a better quality exhaust system  :wink:
Offline jonnyturbo
« Reply #4 on: 16 January 2012, 20:23 »
milltek ?
Offline Rhyso
« Reply #5 on: 16 January 2012, 21:05 »
milltek ?
Why waste his money?  :grin: :grin:
Nick @ R-Tech will vouch for the quality of the system on my Golf  :wink:
Offline cullygti
« Reply #6 on: 16 January 2012, 21:10 »
pro speed are good and milltek seem to be not so good lately quite a few ppl returning them with bad welds etc  :shocked:
Offline Scott D
« Reply #7 on: 16 January 2012, 21:15 »
as suggested try cleaning the throttle body, also coolant temp sensor used to cause stalling at idle when it went on mine.
2003 1.8T GTI 180 - APR Stage I, S2000 Filter, R-Tech Supersize TIP, Bilstein B12 Suspension, 18" OZ Superleggera, Recaro Heated Leathers, US Spec Rear Lights, N249/SAI/PCV Delete
1.8T AUQ - 241bhp & 286 ft-lb
R-Tech Map, Forge FMIC, SFS Oversized TIP, Ported Manifold, Milltek Turboback non res exhaust, Forge 007p, N249 & N112 delete, SAI delete, S2000 Air Filter, Sachs clutch & Lightweight Flywheel
« Reply #8 on: 16 January 2012, 21:36 »
Unplug the maf and see if it runs better.
Offline johnomk4
« Reply #9 on: 17 January 2012, 07:16 »
I got a quote of £600 for an exhaust from pro speed!!! But will admit the quality is top.
