Author Topic: Boost sensor location on AUQ engine  (Read 7297 times)
Offline F17BAD
  • Golf MTM S3 GTI TURBO
« on: 13 January 2012, 12:33 »
Got a AUQ 180 BHP engine to transplant into my dads mk4 2.slow GTI
Donor car is running everything is sweet as a nut but I have fault code 16622 on vagcom which is boost sensor
Anyone know Where is this located on this engine ? We think it could be on the intercooler but not 100%.
Not no ordinary GTI....
www.mixcloud.com/kells/
Offline Chris#101
Re: Boost sensor location on AUQ engine
« Reply #1 on: 13 January 2012, 12:41 »
Theres a map sensor on the smic if thats any help :smiley:
          2003 1.8T: R-tech Live Cutom Stage 2 remap: N249 Bypass : Forge T.I.P : Forge 007p  : Forge Actuator, yellow spring : Toyosports F.M.I.C : Toyosports C.A.I :        PCV simplified - oil catch can : 42' Draft 3" turbo back non res exhaust system : Devils own W.M.I : 231bhp & 258lbs-ft
Offline F17BAD
« Reply #2 on: 13 January 2012, 14:01 »
Yeah I know about the map sensor, my S3 engine in the golf has this too. But been told this isn't the boost sensor?
Offline Adam
« Reply #3 on: 13 January 2012, 18:56 »
The boost sensor is the MAP sensor on the SMIC of the AUQ engine.
Down Hill From Here.
Offline F17BAD
« Reply #4 on: 13 January 2012, 22:17 »
yeap sorry i didn't update, already confirmed this is the sensor in question dude, many thanks tho
So its located on the actual SMIC on the standard AUQ ?
Offline Chris#101
« Reply #5 on: 13 January 2012, 22:49 »
Sure is bud :wink:
As im struggling to figure out how im going to fit my FMIC as theres know where for the map sensor to plug into !?  :undecided:
Offline Scott D
« Reply #6 on: 14 January 2012, 00:12 »
it is on the SMIC
out of interest are you using the AUQ ECU?
I have a problem with that fault code coming up occasionally, tried a few bosch MAP sensors and wiring loom was all ok, was going to swap the ECU but seemed to fix itself and had no fault codes for a good few months now.
Forge IIRC sell a flange that can be welded on to pipework for fitting of a MAP sensor
2003 1.8T GTI 180 - APR Stage I, S2000 Filter, R-Tech Supersize TIP, Bilstein B12 Suspension, 18" OZ Superleggera, Recaro Heated Leathers, US Spec Rear Lights, N249/SAI/PCV Delete
1.8T AUQ - 241bhp & 286 ft-lb
R-Tech Map, Forge FMIC, SFS Oversized TIP, Ported Manifold, Milltek Turboback non res exhaust, Forge 007p, N249 & N112 delete, SAI delete, S2000 Air Filter, Sachs clutch & Lightweight Flywheel
Offline F17BAD
« Reply #7 on: 14 January 2012, 09:42 »
Yeah it's a common thing this code, think carbon can do a bug fix for it
I'm using the factory ECU and factory IC and map sensor location as its just going into a mk4 and as standard as possible just replacing a crap 2.0 8v for my dad
I choose the AUQ because it's 180 BHP rather than 150 and it's doubtfully my dad will map it.. Unless I get Craig to sort a cheeky one out ;/)
I have that forge pipe u mention on my mk3
Offline Chris#101
« Reply #8 on: 14 January 2012, 12:22 »
have you got a link bud, as im desperately trying to find one ?? :sad:
« Reply #9 on: 14 January 2012, 21:36 »
Remap makes a lot of difference and is well worth it.
