Author Topic: Boost sensor location on AUQ engine  (Read 7300 times)
Offline Chris#101
Re: Boost sensor location on AUQ engine
« Reply #10 on: 15 January 2012, 16:08 »
So does anyone have a link for the map adaptor/ flange you need when you fit a fmic to an auq 180???
 :smiley:
          2003 1.8T: R-tech Live Cutom Stage 2 remap: N249 Bypass : Forge T.I.P : Forge 007p  : Forge Actuator, yellow spring : Toyosports F.M.I.C : Toyosports C.A.I :        PCV simplified - oil catch can : 42' Draft 3" turbo back non res exhaust system : Devils own W.M.I : 231bhp & 258lbs-ft
Offline F17BAD
  • Golf MTM S3 GTI TURBO
« Reply #11 on: 15 January 2012, 18:40 »
Got my AUQ engine today along with the 6 speed box, all looms, ECU, intercooler, all pipework, gear linkages, DBW pedal, downpipe with CAT, Ko3s
will prob see craig about a map for it as it needs some codes patching out.
My dad will be pleased with the upgrade in performance over that horrible 2.slow 8v (these are the worst ever engine in a mk4!!!!)
the forge pipe needed to relocate is all over the net!!  google it!
you need to know the size of your pipework, theirs 2 sizes available
http://www.forgemotorsport.co.uk/content.asp?inc=product&cat=&product=FMMAPT
Not no ordinary GTI....
www.mixcloud.com/kells/
