Author Topic: What is this engines code?  (Read 8393 times)
Offline murraymint
« on: 12 January 2012, 17:13 »
Hi, could you tell me the engine code, it's a 1989 Jetta 1.8 8v petrol
josh
Offline Sam
  • Sam I am
Re: What is this engines code?
« Reply #1 on: 12 January 2012, 17:30 »
can you not find any stickers buddy  :smiley:
Offline murraymint
« Reply #2 on: 12 January 2012, 17:33 »
It's in the garage at the minute, needs a gearbox, wanted to know what gearboxes fits it, thort knowing the engine code would be a good start. Also where about on the engine would the code be?
josh
Offline Sam
  • Sam I am
« Reply #3 on: 12 January 2012, 17:50 »
Rear of the block and possibly on the rear of the head too. There should be a sticker in the boot, a sticker on the door/door frame and im sure there is a plate if you quickly whip of all the plastic in the scuttle tray
Offline murraymint
« Reply #4 on: 12 January 2012, 17:51 »
Okay thanks will look when it's back cheers
josh
Offline Sam
  • Sam I am
« Reply #5 on: 12 January 2012, 18:07 »
Have a look through this
http://www.gerritspeek.nl/vag-com_motorcode.html#vw
(ctrl+f is 'find' tool on websites  :smiley: )
Offline Sam
  • Sam I am
« Reply #6 on: 12 January 2012, 18:08 »
Jetta 1.6                            BSE     1595cc  75kW  10-05 t/m 00-00
Jetta 1.6                            BSF     1595cc  75kW  10-05 t/m 00-00
Jetta 1.6 16V.FSI                    BLF     1598cc  85kW  09-05 t/m 00-00
Jetta 1.9 TDI PD                     BKC     1896cc  77kW  09-05 t/m 00-00
Jetta 1.9 TDI PD                     BLS     1896cc  77kW  09-05 t/m 00-00
Jetta 2.0 16V.FSI                    BLR     1984cc 110kW  09-05 t/m 00-00
Jetta 2.0 16V.FSI                    BLY     1984cc 110kW  10-05 t/m 00-00
Jetta 2.0 16V.TFSI                   BWA     1984cc 147kW  09-05 t/m 00-00
Jetta 2.0 TDI PD 16V.                BKD     1968cc 103kW  09-05 t/m 00-00
Jetta 2.0 TDI PD 16V.                BMM     1968cc 103kW  10-05 t/m 00-00
Jetta I 1.3                          GF      1272cc  44kW  01-80 t/m 01-84
Jetta I 1.5                          JB      1457cc  51kW  01-80 t/m 01-84
Jetta I 1.5 AUTOM.                   JB      1457cc  51kW  01-80 t/m 01-84
Jetta I 1.6                          FR      1588cc  63kW  01-80 t/m 01-84
Jetta I 1.6 D.                       CR      1588cc  40kW  11-80 t/m 01-84
Jetta I 1.6 D.                       JK      1588cc  40kW  11-80 t/m 01-84
Jetta I 1.6 D.AUTOM.                 CR      1588cc  40kW  11-80 t/m 01-84
Jetta I 1.6 D.AUTOM.                 JK      1588cc  40kW  11-80 t/m 01-84
Jetta I 1.6 INJ.                     EG      1588cc  81kW  01-80 t/m 08-82
Jetta I 1.6 TD.                      CY      1588cc  51kW  08-82 t/m 01-84
Jetta I 1.8 INJ.                     DX      1781cc  82kW  09-82 t/m 01-84
Jetta II 1.3                         2G      1272cc  40kW  10-86 t/m 01-89
Jetta II 1.3                         HK      1272cc  40kW  02-84 t/m 09-86
Jetta II 1.3                         MH      1272cc  40kW  02-84 t/m 09-86
Jetta II 1.3                         MH      1272cc  40kW  10-86 t/m 01-89
Jetta II 1.3 INJ.                    NZ      1272cc  40kW  02-89 t/m 04-92
Jetta II 1.6                         EZ      1588cc  55kW  02-84 t/m 09-86
Jetta II 1.6                         RF      1588cc  53kW  10-86 t/m 04-92
Jetta II 1.6 AUTOM.                  EZ      1588cc  55kW  02-84 t/m 09-86
Jetta II 1.6 D.                      JP      1588cc  40kW  02-84 t/m 04-92
Jetta II 1.6 D.AUTOM.                JP      1588cc  40kW  02-84 t/m 04-92
Jetta II 1.6 TD.                     JR      1588cc  51kW  02-84 t/m 10-90
Jetta II 1.6 TD.IC.                  SB      1588cc  59kW  10-90 t/m 04-92
Jetta II 1.6 TD.KAT.                 1V      1588cc  44kW  01-90 t/m 04-92
Jetta II 1.8                         GU      1781cc  66kW  02-84 t/m 09-86
Jetta II 1.8 AUTOM.                  GU      1781cc  66kW  02-84 t/m 09-86
Jetta II 1.8 GTI 16V.                PL      1781cc  95kW  01-87 t/m 10-91
Jetta II 1.8 INJ.                    EV      1781cc  82kW  01-85 t/m 09-86
Jetta II 1.8 INJ.                    GX      1781cc  66kW  10-86 t/m 10-87
Jetta II 1.8 INJ.                    PF      1781cc  79kW  10-87 t/m 04-92
Jetta II 1.8 INJ.                    RD      1781cc  79kW  10-86 t/m 10-87
Jetta II 1.8 INJ.                    RP      1781cc  66kW  08-87 t/m 04-92
Jetta II 1.8 INJ.SYNCRO              GX      1781cc  66kW  08-87 t/m 10-91
glove
« Reply #7 on: 12 February 2012, 23:01 »
« Last Edit: 22 April 2012, 00:46 by glove »
Offline clipperjay
« Reply #8 on: 13 February 2012, 12:07 »
Sam's bored?
glove
« Reply #9 on: 13 February 2012, 14:57 »
« Last Edit: 22 April 2012, 00:45 by glove »
