Author Topic: Another dreadid HID question..sorry ladies and gents.  (Read 1359 times)
Offline MrRogers
Evening all,
Hope this is the right section to ask. I don't at the moment have HID's neither projectors at the moment. As were all aware the new MOT rules regarding HIDs bla bla bla..
Just curious to no will the MOT fail if you have the HID kit installed or is it just the brightnes of the light output from the bulbs them selves?
Cheers for the input.
2000 Golf MK4 1.8 AGU black magic, Custom Code stage 1 remap, Forge 008, Simota Aeroform CAI, G60/VR6 Combo, Weitec GT Hicon coilovers, Golf GTI MK5 18" Monza style alloys, 10mm H&R spacers front + 20mm H&R spacers rear, OEM Polo MK5 aerial, Whiteline front ARB + Whiteline droplinks.
Offline clancy
Re: Another dreadid HID question..sorry ladies and gents.
« Reply #1 on: 10 January 2012, 22:51 »
if they are not particularly bright, or you have the correct bulbs. ( you can get HID bulbs made for reflector lenses so they are not too bright now) then its unlikely they would check tbh. unless there bright blue etc.
unless you go to some big chain garage which is likely to check everything in the book etc
other option is fit them after you MOT
MK3 GTI 16v
Offline javalin
« Reply #2 on: 12 January 2012, 13:37 »
>another option is fit them after you MOT
not really as they'll fail the next MOT and be an issue if you are ever stopped for anything....
of course all MOT centres should be to the same standard.
I believe they have to be fitted correctly and have working auto-adjuster's fitted to pass the MOT, plus the installation needs to be tidy cause you can now fail on bad/loose wiring, etc
James
You only ever need two tools in life. If it moves and it shouldn't use Duct Tape. If it does not move and it should, use WD40.
