Author Topic: XSD vagcom adjust  (Read 5910 times)
Offline mkviken
XSD vagcom adjust
« on: 10 January 2012, 16:32 »
has anyone adjusted their electronic diff via VCDS?
you can have it on 0 (standard), 1 (medium) or 2 (strong).
as far as i can find setting 2 is recommended for track use.
Golf GTI 7.5 230 white silver
Offline mkviken
Re: XSD vagcom adjust
« Reply #1 on: 10 January 2012, 16:36 »
oh yes and the golf R and scirocco R both come from the factory in setting 2.
might be worth tinkering with
« Reply #2 on: 10 January 2012, 18:13 »
Wish I'd known this when I had my REVO'd car, it could have cut down on the torquesteer.
I may have a play in the spring anyway, so thanks for the info.  :cool:
Offline Keithuk
« Reply #3 on: 10 January 2012, 19:22 »
XSD vagcom adjust
Don't you mean XDS?  :wink:
Update:
I've just read these XDS Settings WOW!!!
ESP, XDS, DSR, ASR, Brake Assist, Hill Hold Control Settings Vag-Com
It appears you can switch the ESP off.
« Last Edit: 10 January 2012, 19:49 by Keithuk »
2010 Golf GTD (170) CBBB, 5 Door, Shadow Blue (P6/D5Q), Flat Tyre Indicator, Basic Protection Pack + VCDS.
Offline mkviken
« Reply #4 on: 10 January 2012, 20:17 »
I can switch mine off as I have a 2012MY car. Don't need VCDS to deactivate it.
Offline Snoopy
  • Moderator
  • Geoff.
« Reply #5 on: 10 January 2012, 20:28 »
Nice find mkviKen. Guess you and Damien have been playing. Your Panel is due Thursday so should have it for the weekend :smiley:
Mk6 GTI  &  Mk1 GTI
35 years of GTI ownership.
Offline mkviken
« Reply #6 on: 10 January 2012, 20:43 »
Not tried it yet but will definately activate stage 2 diff setting as soon as someone with VCDS is willing! Hint hint
Read a few scirocco sites giving it great reviews. Helps car stop washing wide on the gas. Brake pads won't thank you for it though as the 'diff' will be working overtime!
Just let me know when I can pick the undertray up. Thanks for sorting it for me.
Offline Snoopy
  • Moderator
  • Geoff.
« Reply #7 on: 11 January 2012, 11:51 »
If no change at home, i could prob do it at the weekend as its only 5 mins.
Mk6 GTI  &  Mk1 GTI
Offline mkviken
« Reply #8 on: 11 January 2012, 12:29 »
i had a word with Damien and he's going to have a go at it. think I'm going tomorrow night. if the under tray is there i will call in at yours too while I'm over that way.
cheers
Offline mkviken
« Reply #9 on: 11 January 2012, 15:04 »
to change the settings via VCDS
go to adaptations> channel 36 > and then set a value from 0 to 2. This adjusts the sensitivity.
In 0 rarely intervenes.
In 1 its weak.
In 2 it's strong.
I'm going to try 2 which is used on the R20 and rocco R
think this is worth trying if you have a remap especially.
