Author Topic: XSD vagcom adjust  (Read 5928 times)
Offline Snoopy
  • Moderator
  • Geoff.
Re: XSD vagcom adjust
« Reply #10 on: 11 January 2012, 15:10 »
I probably won't have the undertray till the weekend as the lad whos getting it would not be picking it up till Friday morning.
Mk6 GTI  &  Mk1 GTI
35 years of GTI ownership.
Offline Keithuk
« Reply #11 on: 11 January 2012, 18:53 »
I can switch mine off as I have a 2012MY car. Don't need VCDS to deactivate it.
Yes I can switch mine off without VCDS but the flashing light is annoying.  :grin:
2010 Golf GTD (170) CBBB, 5 Door, Shadow Blue (P6/D5Q), Flat Tyre Indicator, Basic Protection Pack + VCDS.
Offline mkviken
« Reply #12 on: 11 January 2012, 19:08 »
No it's different to what I have. I have 2 stage ASR/ESP activation.
If I hold the button down for 3 seconds it deactivates the ESP so you can slide it etc but if it detects it is in an 'extreme' situation and you brake ESP is immediately reactivated and it will try and correct the car so it's a bit of a safety net.
Anyway. Tonight I activated stage 2 on the diff and the car does turn tighter and feels more agile and doesn't push on anywhere near as much. Round tight turns on hard throttle it seems to holds a line much better even though it was very slippery tonight while driving home.
I think in the dry it will definately make the car turn better and get the gas on earlier.
Golf GTI 7.5 230 white silver
Offline Snoopy
  • Moderator
  • Geoff.
« Reply #13 on: 11 January 2012, 21:49 »
 :smiley:
Mk6 GTI  &  Mk1 GTI
Offline mkviken
« Reply #14 on: 11 January 2012, 22:05 »
No rush for it mate
Im going to give the underbody a good clean before I fit it anyway.
Bought an extendable hose thing with a pivot head ideal for getting under the car to get the salt off etc.
Are you going to try the XDS setting Geoff?
You can also adjust how much brake assist you get so you can make the pedal more sensitive.
Offline Hurdy
« Reply #15 on: 11 January 2012, 22:09 »
Hmmm, wonder what XDS on the Polo GTI is set at?
Seat Leon Cupra Black 290 DSG
Offline Snoopy
  • Moderator
  • Geoff.
« Reply #16 on: 11 January 2012, 22:13 »
I may try it. Need the irritating throttle pedal looked at first as everytime i take my foot off the throttle it makes a click noise. They all do this but normally you don't hear it due to distance away from it and background noise but mines now louder and i hear it over the radio & heater, it was driving me nuts in stop start traffic the other day to the point ive been using the other car since!
Im sure the dealer will say there all like that even though its only been like this for a month  :grin:
« Last Edit: 11 January 2012, 22:16 by Snoopy »
Mk6 GTI  &  Mk1 GTI
Offline mkviken
« Reply #17 on: 11 January 2012, 22:17 »
Could you just stick some felt tape on the 2 serfaces that are touching?
Offline Snoopy
  • Moderator
  • Geoff.
« Reply #18 on: 11 January 2012, 22:19 »
It sounds like the microswitch of the potentiometer thats making the noise.
You will have to send me a link to your supplier of felt tape i may as well do the door panels when i have them off to fit the door lights.
Mk6 GTI  &  Mk1 GTI
Offline mkviken
« Reply #19 on: 11 January 2012, 22:41 »
I just got a roll on eBay for about £6 or so
I need to do my doors too as there is a slight rattle from around the window switch I think.
