Author Topic: need help to find the right fuse  (Read 5165 times)
Offline golf-sib
  • Турботазик
Re: need help to find the right fuse
« Reply #10 on: 06 January 2012, 19:37 »
thanks  :smiley: fuse number 7 has blown and typically thats one out the replacement set that has been used.  it seems that this is the speedometer fuse. but on the cars paper stuck to the fuse panel, it says its for the reverse lights are they run of the same fuse then
Could do, when my lights went in the car so did central locking, no fuse lab belled as central locking, so when I changed light fuse which was blown out so did the locking mechanism. Them diagrams are as clear as mud.
VW Golf - k03 AGU - 200BHP
1.8T AGU..
R135
  24
Offline lissy7
« Reply #11 on: 07 January 2012, 09:55 »
the fuse has been changed and speedo and fuel gauge issues fixed,but sadly hasnt fixed the reversing lights.
Offline richw911
« Reply #12 on: 07 January 2012, 10:03 »
Did you check the wires on top of the reverse switch?  :smiley:
Offline lissy7
« Reply #13 on: 07 January 2012, 10:12 »
wires checked and switch changed,
but i wonder if the wires going to the actual bulbs have got pinched or a wire has got pulled out.
as all the other lights works but several have very sensitive wiring slightest movement and the rear passenger light fail.
also can find out why the boot internal light doesnt work and cant gain access behind it to check that wiring
Offline richw911
« Reply #14 on: 07 January 2012, 10:18 »
Check all the contacts and the plug in the bulb holder  :smiley:
The boot light - does you rear washer work? Even if id does see this :
http://www.golfgtiforum.co.uk/index.php?topic=150271.0
Offline lissy7
« Reply #15 on: 07 January 2012, 10:29 »
 :smiley:   thanks i wonder if that means when the boot was replaced the person didnt wire the boot up properly as the boot symbol doesnt come up on the dash.
that link looks good
it would be nice to have a few weeks without  the car having a new issue  :rolleyes:
Offline richw911
« Reply #16 on: 07 January 2012, 10:42 »
Some cars don't have the boot light in the clocks mine doesn't   :wink:
lol  :laugh:
Offline lissy7
« Reply #17 on: 07 January 2012, 15:55 »
fair point  :smiley: the boot symbol should come up on the dash if the boot is open tho? and it hasnt since it was bought last year
Offline richw911
« Reply #18 on: 07 January 2012, 16:28 »
What year is the car? I mean some cars dont have a light / Boot symbol at all like mine  :smiley:
Offline Steve_PD
« Reply #19 on: 07 January 2012, 17:33 »
x reg 2000
