Author Topic: need help to find the right fuse  (Read 5165 times)
Offline lissy7
Re: need help to find the right fuse
« Reply #20 on: 07 January 2012, 18:23 »
yeah Xreg 2000  :smiley:
Offline lissy7
« Reply #21 on: 07 January 2012, 18:25 »
if it shouldnt have a symbol then i am less fussed.
Offline lissy7
« Reply #22 on: 09 January 2012, 15:20 »
help the fuse has blown to the speedo 3 times today,i dont understand what is going on. any ideas gratefully received at a loss really
Offline richw911
« Reply #23 on: 09 January 2012, 15:24 »
Short somewhere - what else runs off that fuse?
Offline lissy7
« Reply #24 on: 09 January 2012, 15:39 »
well there is the issue,the only other thing that seems to go wrong when the fuse goes is the fuel gauge,
but i wondered if it happened when the brake and reverse switch and wires were changed last week.
but as with most vw cars the reverse havent worked for months and months and in some manuals the same fuse is responsible for the reversing lights  :rolleyes:
Offline richw911
« Reply #25 on: 09 January 2012, 15:49 »
Could be faulty clocks - but to try another set you will need someone to code them in  :sad:
Offline richw911
« Reply #26 on: 09 January 2012, 15:55 »
Found this lots of info here http://uk-mkivs.net/forums/p/286882/1895791.aspx  :smiley:
Offline richw911
« Reply #27 on: 09 January 2012, 15:59 »
And this sounds like it is the wiring to the speed sensor under the battery  :smiley:
http://uk-mkvs.net/forums/p/380019/2591905.aspx
Offline lissy7
« Reply #28 on: 09 January 2012, 16:04 »
the strange thing is that the temperture gauge etc are fine purely the fuel and speedo. it is fuse 7 on the x reg 3dr right hand drive 1.8gti aum. i just phoned a vw dealership they said they thought it was unlikely we would be able to find what was causing it and we need to check the wiring that was done last week as that could have pulled something
but i have so little knowledge of the wiring of the car.i am not clear where the wires from the reversing sensor switch and casing thingy have both been changed goes except the gear box.  i know i that sounds a bit daft but i am a newbie to vw's
i hope we dont have to change the clocks as the clifford all singing all dancing alarm system runs through it as well as everything.
do u think if i found a someone with a fault code reader.it would be giving the correct or because it might have shorted out it would be giving random readings.
thanks again
Offline lissy7
« Reply #29 on: 09 January 2012, 16:06 »
oops sorry just seen ur other posts,wicked i will check the wiring tonight.  :smiley:
