Author Topic: 16v slight idle problem  (Read 3829 times)
Offline 01664gti
  • mk3 hatch mk3 wagon and mk2 16v
« on: 05 January 2012, 23:30 »
Hi guys
Im slowly starting to get my 16v ready for the road,I have just got it back from mot and the guy noticed that the tps is unplugged.I never noticed tbh as i bought it with no mot and have only driven it about 1 mile lol.
Anyway it idles fine with it unplugged but when i reconnect the tps the idle changes intermittantly from 1000-900 etc,Its not a massive issue but bugs me none the less.
Is the tps likely to be at fault or could something else make the tps act up.
you help would be great
Offline mk2bal
Re: 16v slight idle problem
« Reply #1 on: 06 January 2012, 08:23 »
Its not a tps as such, more of a closed throttle switch to activate the isv. It sounds like your isv is faulty or dirty, and its been unplugged and idle speed screw adjusted to compensate for this. I assume you are talking kr 16v...
Offline walchy01
« Reply #2 on: 06 January 2012, 09:41 »
If i remember correctly when mine was doing this, i was advised to pull out my tick over screw(i think) and clean both the screw and the fitting, it helped me :grin:
Someone will correct me if i'm wrong.. :embarassed:
Offline 01664gti
« Reply #3 on: 06 January 2012, 16:27 »
Mk2 bal yes kr 16v,I had the isv problem on my 8v and also my e30 which i cured with the cleaning method.But i thought that as the switch was unplugged it may be of fault especially as it runs fine without it plugged in.So if i plug it back in as it should be and clean the isv it may be ok??
Walchy i may as well try your method too while im at it lol
Offline clipperjay
« Reply #4 on: 06 January 2012, 17:08 »
Have you considered the switch is stuck or broke and thats why its unplugged?
 :grin:
Offline 01664gti
« Reply #5 on: 06 January 2012, 17:17 »
 :grin:
Im open to all ideas lol,can the switch be replaced on its own ??
Offline clipperjay
« Reply #6 on: 06 January 2012, 17:20 »
Have you pushed it in to see if you can hear the click noise?
Offline 01664gti
« Reply #7 on: 06 January 2012, 17:21 »
i shall nip out in a sec and try  :smiley:
Offline 01664gti
« Reply #8 on: 06 January 2012, 18:05 »
i can hear a click when i push the micro switch in.The throttle mech seem a bit stiff and also the cable seems a bit slack so will get some carb cleaner and jizz it all out and i will also do the isv at the same time.
Any particular method to it or just the norm??
Offline clipperjay
« Reply #9 on: 06 January 2012, 18:09 »
Just clean and re grease the cable
TBH most people will run it unplugged as getting one that will fit is a nightmare, meaning I had to buy a second hand TB just to knick the switch then re tap screw holes as some are plastic welded onto the TB.
All it does is retards the fuel at rest to save fuel in idle mode.
