Author Topic: 16v slight idle problem  (Read 3830 times)
Offline 01664gti
  • mk3 hatch mk3 wagon and mk2 16v
Re: 16v slight idle problem
« Reply #10 on: 06 January 2012, 18:13 »
All it does is retards the fuel at rest to save fuel in idle mode
So if i run it as is i will not lose any performance or use extra fuel etc??.
I would sooner have it plugged in and working but if after the clean its still the same ill just run as is.
Offline clipperjay
« Reply #11 on: 06 January 2012, 18:27 »
yeah yours should be fine its seems to be broke one way proberly open as if it was broken with retarding the fuel you would know about it i.e no power and hesitation. But your set up has proberly been modded to take any difference the fueling would have made to the response. So plugging it back in which would require a tune up again
Offline mk2bal
« Reply #12 on: 06 January 2012, 20:48 »
It doesn't control fuel, when the throttle is shut it switches on the isv, which allows a metered amount of air in, for steady idle. The fuel follows the air, via the metering head. Mine makes little difference with isv unplugged also though, seems to idle fine without it..
