Cosmetic and bodywork matters
Dropped door hinges
Topic: Dropped door hinges (Read 2456 times)
Splinter
GTI forum regular
Dropped door hinges
13 May 2005, 15:13 »
Drivers side door as usual, you have to slam it a little harder to shut it (especially with the speakers and dynamat weighing it down!)
How do you go about fixing the problem?
or are new hinges required?
" Do it today, Don't wait until tomorrow "
The Hoax
GTI forum regular
Re: Dropped door hinges
13 May 2005, 18:17 »
Open the door and shake it up and down. If you feel any play you will probably need a new hinge. They are not expensive but a bit of a Gareth Hunt to fit. The top and bottom hinges are the same and it is likely to be the bottom one that is gone.
Take the door off ( dead easy) and you have to drive the pin out that holds the hinge to the door. I tried this but couldn't move it so I took the door to a body shop and bunged the guy a few quid to do it for me. Just drive in the new pin and you are sorted.
Splinter
GTI forum regular
13 May 2005, 18:22 »
Thanks, will have a play in a few weeks. Like u say, the bodyshops repair guys remove doors all day so they might be best to sort it if I cant so easily. My mate can probably do it for me when he's less busy.
VR6_ROB
Mk2 VR6 / Corrado G60
15 May 2005, 16:39 »
i welded my hinge good as new now
Dropped door hinges
