Author Topic: Boot lock  (Read 5990 times)
Offline scottishpedro
Boot lock
« on: 01 January 2012, 13:20 »
Happy New Year to you all
I am havin trouble with my 1990 8v central locking.  All the doors lock fine but the boot isn't locking, I can hear the mechanism but it's not working.  I found the following helpful post :
"If your boot wont lock at all I imadgine you have the very same problem I had untill this weekend.
You probally already know the locking positions of the boot key slot, but just encase horizontal with the key turned fully to the right = always open, vertical = alwasy locked and horizontal key turned all the way left = unlocked/locked depending on central locking.
If you pop off the plastic panel on the inside of the boot lid (held on my 5 push clips) you will reveal the back of the lock and the wiper motor etc. on the right hand side of the boot panel there will be a blue 'pod' with a rubber hose coming out of it followed by a brass looking rod which doubles back on itself and runs from right - left to the center of the boot and onto the mechanism which connects the push button on the boot to the lock/catch.
The rod runs through this mechanism (behind the white hooky thing) and out the other side. It is responsible for pushing the white plastic clip from side to side to lock/unlock the boot (technically its always unlocked but when the white hook is moved the button does not come in contact with it so you cant open it)
I had to use about a pint of WD40 and wiggle the long bar from left to right for about 5 minutes to free it up as mine was stuck solid. It would try to move and buzz etc, realise it was seized and give up. Which sounds like what is happening to you?
I found it helped to put a screw driver between the left hand side of the piece of metal which the white hooky thing sits in because without it the whole mechanism started to give a little instead of just the bar which goes through it.
After finnaly getting it loose and moving it back and forth whilst spraying in WD40 it now locks like a charm.
Hope that helps with the boot issue at least?"
I'm going to try following that guide.  One thing I have noticed though is my key does not turnat all I the boot, should this be the case?
Thanks
Pedro
Offline X4MGS
  • VAG Parts SNOB!!!
Re: Boot lock
« Reply #1 on: 01 January 2012, 13:23 »
Sound like your lock has seized (Are you sure it's the correct key for the lock?)...
I would use Grease and not WD40 on the long bar where it fits onto the white slider on the button mech..
HTH
For More Info Click To See;
Re: Boot lock
« Reply #2 on: 01 January 2012, 13:27 »
HTH
Hi,
I only have 2 keys which both work the drivers door but not the boot.  Just about to start investigating the lock now, and then maybe try and sort the sagging roof lining and squeaky seatbelt If I can!
Offline X4MGS
  • VAG Parts SNOB!!!
Re: Boot lock
« Reply #3 on: 01 January 2012, 13:30 »
HTH
Hi,
So Has one of the keys ever opened the boot lock??
If it's the wrong lock & key it would never open!! So No point trying to lube up barrel... :laugh: :laugh:
Re: Boot lock
« Reply #4 on: 01 January 2012, 13:35 »
I have never tried a key in the boot lock.  The keys which operate the central locking from the drivers door, and the central locking should operate the boot lock with normal function?
Offline X4MGS
  • VAG Parts SNOB!!!
Re: Boot lock
« Reply #5 on: 01 January 2012, 13:43 »
Factory Central Locking ONLY works from the drivers door...
But you should be able to manually open the other locks with a key...
Re: Boot lock
« Reply #6 on: 01 January 2012, 13:45 »
HTH
Hi,
Ah, I think we have crossed wires, I think I know what you mean.  It's looks like there are 2 problems, the central locking mechanism not working and the actual boot lock clogged with crap.  Good news is central locking now fixed (easy!), just trying to declog lock now
Re: Boot lock
« Reply #7 on: 01 January 2012, 14:04 »
Ok so while I'm at it, onto the stiff driver side rear door
I have worked out that when the handle is pulled the pin doesn't seem to fully move down to allow the metal c shape to release.  Is this most likely to be the handle mechanism (I.e cable needs adjusted if possible)?
Ta
Pedro
Offline X4MGS
  • VAG Parts SNOB!!!
Re: Boot lock
« Reply #8 on: 01 January 2012, 14:05 »
Ta
Pedro
Inside handle or outside one??
Re: Boot lock
« Reply #9 on: 01 January 2012, 14:12 »
Outside only
