Author Topic: Boot lock  (Read 5991 times)
Offline X4MGS
  • VAG Parts SNOB!!!
Re: Boot lock
« Reply #10 on: 01 January 2012, 14:21 »
If its a genuine one - Take it off and grease up the spring and mech...
If it's a copy - Bin it and get an Original one... :wink:
For More Info Click To See;
Offline Thom89
  • Looking for an "Icebreaker"
Re: Boot lock
« Reply #11 on: 01 January 2012, 14:42 »
A common problem for the boot lock not working properly, can be the little white clip, that is attached to the opposite end of the rod coming from the C/L unit in the tailgate, this clip should be mounted securely to the rod, so it moves with it, but over time, the clip can become loose, and the rod passes straight through it, giving the impression that its actually working OK, when in fact its doing nothing!
Thom
Offline scottishpedro
Re: Boot lock
« Reply #12 on: 01 January 2012, 16:05 »
Thanks got the central locking sorted.  Need to get some decent adhesive to resticj the rear roof lining back on, any suggestions?  Also checking levels, I find it very hard to see the fluid levels as the plastic i presume has aged and is less translucent, particularly coolant and brake levels.
Offline Mitching
Re: Boot lock
« Reply #13 on: 01 January 2012, 21:02 »
I'm having the exact problem with mine but I don't have central locking.
The key won't turn in the lock to lock it.
Will the problems mentioned be the same with mine?
Is it mechanically broken or would it be seized?
Offline X4MGS
  • VAG Parts SNOB!!!
Re: Boot lock
« Reply #14 on: 01 January 2012, 21:13 »
You'd need to strip it down and look - but sounds like something is broken or missing...
Offline golfnut8v
Re: Boot lock
« Reply #15 on: 01 January 2012, 22:44 »
pete reply to the back door, drivers  side...its the strike pin thats needing adjusted...
this is the little pin mounted to the body, :laugh:
Offline Mitching
Re: Boot lock
« Reply #16 on: 01 January 2012, 23:50 »
:afro: Nice one, I'll give it a go tomorrow.
Is it a fiddly job?
Offline X4MGS
  • VAG Parts SNOB!!!
Re: Boot lock
« Reply #17 on: 02 January 2012, 00:12 »
Is it a fiddly job?
Yes It can be...
Offline Thom89
Re: Boot lock
« Reply #18 on: 02 January 2012, 00:14 »
Is it a fiddly job?
Do you have another pic, showing the clip that sits on the end of the CL operating rod for the tailgate?
Thom
Offline X4MGS
  • VAG Parts SNOB!!!
Re: Boot lock
« Reply #19 on: 02 January 2012, 00:22 »
Thom
Bit Naff On The Central locking as the parts for the barrel aren't shown...
