Author Topic: reaccuring problem  (Read 833 times)
Offline Tazzy
reaccuring problem
« on: 30 December 2011, 00:47 »
considering ive spent over £800 on the engine, you would think i had solved all problems, guess not
just finished work, turned the key, with clicking from behind the dash i know to be the fuel relay, but there was also a popping sound from the engine, i opened the bonnet to a burning smell, that soon went, turned the key again to hear a winey noise and a clicking noise from the engine also, obviosuly this isnt right
im also getting the clicking from the fuel relay as im driving, this is then followed by the car julting/pulling then a pop from the exhaust, this feels like its starving itself of fuel then cutting back in, like an 'overfuel'
would this be a case of just a new fuel relay, or is it something more severe?
cheers ta, thanks very moochos
If It Comes Off, Modify It!
Offline richw911
Re: reaccuring problem
« Reply #1 on: 30 December 2011, 11:38 »
Fault codes?
Offline Tazzy
« Reply #2 on: 30 December 2011, 16:54 »
ive had a new ecu so im expecting to to be clear, will need another reading i guess :(
Offline richw911
« Reply #3 on: 30 December 2011, 17:09 »
Get a cheap reader it really is a must with a mk4  :wink:
