Author Topic: which mk3 cabs have hyd clutch  (Read 2763 times)
Offline red shed
« on: 29 December 2011, 15:11 »
im looking for a mk3 cab as a project to transplant a vr6 into, and as the vr6 is hydrualic clutch and cable gear change which mk3 cabs come with the same set up.
thanks in advance
Re: which mk3 cabs have hyd clutch
« Reply #1 on: 29 December 2011, 15:49 »
None from memory they were all cable, only mk3's that were hydraulic were 16v's and VR's, biggest engine in the cabrio was a 2.0 and that I am sure ran a cable clutch.
Offline mad4vws
« Reply #2 on: 29 December 2011, 20:48 »
yeah all mk3 cabs have cable set up same as 8v gti running gear , best of taking stuff of a tdi or gti 16v as they are hyd setup. :wink: :smiley:
BREAKING VW GOLF'S
Mk2/ MK3'S ALL DAY LONG. PM FOR ANY PARTS!!  ON 07813936583
« Reply #3 on: 29 December 2011, 20:51 »
One point that might be worth checking is that later hatches have the same pedal box so the hydraulic cylinder will fit in with no mods, you might find the cabrio is the same.
Offline sharki786
  • GOT BOOST??
« Reply #4 on: 29 December 2011, 20:55 »
what does this pedal box look like?
*****MK3 Anniversary*****
*****MK4 GTI T*****
« Reply #5 on: 29 December 2011, 20:56 »
From the threads I have read it is standard on all 1996 onwards cars.
Offline F17BAD
  • Golf MTM S3 GTI TURBO
« Reply #6 on: 30 December 2011, 17:48 »
yours has the one thats needed, thats all u need to know :wink:
Not no ordinary GTI....
www.mixcloud.com/kells/
Offline red shed
« Reply #7 on: 30 December 2011, 18:11 »
looks like im going to have to use pedal box from the passat vr6 donor car as well as the gearchange set up aswell, looks like a bigger job than i,d hoped for.
Offline F17BAD
« Reply #8 on: 30 December 2011, 18:21 »
WHY ? how old is the Cab ?
Not worked on a cab, but 95% sure you will have the correct pedal box
« Reply #9 on: 30 December 2011, 18:33 »
Passat is very different to the Golf, not sure how easy it will be to convert into the cabrio.
