Author Topic: which mk3 cabs have hyd clutch  (Read 2765 times)
Offline Diamond Hell
  • Opinions я Us
Re: which mk3 cabs have hyd clutch
« Reply #10 on: 30 December 2011, 19:26 »
looks like im going to have to use pedal box from the passat vr6 donor car as well as the gearchange set up aswell, looks like a bigger job than i,d hoped for.
Gear-shift should be relatively easy, just route the cables neatly and away from the exhaust.
You can always use the cable-clutch conversion off a SEAT Toledo or similar instead of converting to hydro.
Offline red shed
« Reply #11 on: 31 December 2011, 16:21 »
ive not got the cab yet, thats why im trying to get as much info as poss before purchase, i do have the passat vr6 tho, complete and ready to strip.
would it just be easier to put the golf cab gearbox onto the vr6 lump from the passat?
Offline F17BAD
  • Golf MTM S3 GTI TURBO
« Reply #12 on: 31 December 2011, 16:31 »
Gearlinkage is piss easy to swap out, you will be using the one from a ABF mk3 or VR6 and the Gearbox from a VR6 too
Will also need the Clocks from a Golf VR6
The pedal box will probably be ok, its only the very early MK3's that don't have provisions on the pedal box for the Hydro parts
Id personally not go down the cable to hydro route on this application..
Would have been much better using a golf 3 VR6 as the donor, you can get them for as little as £500
Not no ordinary GTI....
www.mixcloud.com/kells/
Offline sharki786
  • GOT BOOST??
« Reply #13 on: 31 December 2011, 21:26 »
what does this pedal box look like?
yours has the one thats needed, thats all u need to know :wink:
cheer kells :wink:
*****MK3 Anniversary*****
*****MK4 GTI T*****
Offline red shed
« Reply #14 on: 01 January 2012, 19:53 »
reason i got the passat vr6 is i drive a passat as my daily and  the vr6 had full heated leather, so had it for that and break rest for spares for guys on another forum(ukpassats)
Offline Adam
« Reply #15 on: 01 January 2012, 21:53 »
If you can change a clutch you can swap from cable/rod to hydro/cable. I did it.
Down Hill From Here.
