Author Topic: VR6 MAF HOUSING UPGRADE ISSUES  (Read 807 times)
Offline Roystar
« on: 22 December 2011, 18:33 »
I have recently upgraded my 1.8t agu turbo to a ko4-001 I am getting all the bits ready for a re-map I am a bit stuck with what I actually need for the VR6 MAF Housing, firstly the TIP is there one that fits directly on to turbo and 3" housing or will I need some sort of reducer or could I put a reducer on the MAF housing to existing TIP? Secondly I would like to run a 3" CAI from the right front arch completely away from the engine bay with the hope I don't drive though to bigger puddle, there are loads of kits for standard GTI but I need 3". The Job is not the hardest but will take a bit of customizing just wondering if there would be an easy option.
Offline Dave_IOW
Re: VR6 MAF HOUSING UPGRADE ISSUES
« Reply #1 on: 22 December 2011, 19:02 »
Exactly what im getting to do bud, i think if you stretch a silicone TIP enough, if will squeeze over MAF housing enough. I dont think the difference is that much, may take some perseverance though.
CAI wise, ive bought a 3'' foam filter, and a 3'' S/Steel pipe with 45degree bend with 160mm legs.
This will put your filter down the right hand side of your battery away from heat and run a pipe from filter down to front bumper to get direct cold air in.
No chance of hydrolock and nice cold air into your turbo.
Project: Mk2 20vT trackslag
Daily: Mk2 GTI typ19
Offline Roystar
« Reply #2 on: 22 December 2011, 19:07 »
Where did you buy the 3" Pipe from or did you have it custom made? down at the battery sounds like a good idea, down at the arch is asking for trouble
Offline Dave_IOW
« Reply #3 on: 22 December 2011, 19:36 »
Ebay bud.
http://www.ebay.co.uk/itm/130539554066?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1438.l2649#ht_1750wt_952
Using a RAM air foam filter, i bought off here for a tenner. Just remember to not buy an oiled one  :afro:
