Author Topic: Interior fan not blowing hot air  (Read 3127 times)
Offline Michelleywelly
« on: 22 December 2011, 16:23 »
As above, maximum hot temperature and not blowing hot air inside the car. does anyone know any reasons why? the relay has been re-newed and the fan is still working on numbers 2,3, and 4 by the switch. also have to give the fan a thump to get it working sometimes.
any ideas?
Cheers!! :sad:
Offline javalin
Re: Interior fan not blowing hot air
« Reply #1 on: 22 December 2011, 21:48 »
heat exchanger faulty or airlock in coolant
You only ever need two tools in life. If it moves and it shouldn't use Duct Tape. If it does not move and it should, use WD40.
Offline Seanl
« Reply #2 on: 22 December 2011, 22:01 »
Whats your water temp like? Also what car? Old ones suffer with dodgy bypass valves or blocked heater matrices.
« Reply #3 on: 24 December 2011, 00:19 »
Hi there, thanks for the reply.
its a Mk 4 (1999) golf
she has had the tendency to over heat. but this is quite rare. is this a job for auto technicians?
i am a bit wary to send my car into garages, as they do work that doesnt need doing....or say theyve done the work when they havent. i try to do things myself. but this heater has confused the hell out of me............. :laugh:
« Reply #4 on: 24 December 2011, 00:38 »
hi there, thanks for that  :smiley:
how would i know for defo?? coz these garages around here charge by the hour  :laugh:
even then, they tell u something else different is wrong with the car  :grin:
Offline javalin
« Reply #5 on: 24 December 2011, 08:38 »
try bleeding it - there is a sticky somewhere - but essentially, start it from cold with the expansion cap off, let it warm up (will take ~15mins) and massage coolant hoses.  Once its hot and the t-stat is open, all hoses including radiator will be hot.  Switch off and put cap back on.  Oh and put dial in cabin to full hot to let water/air flow.
if its still cold then its the heat-exchanger.
James
(PS - assumes that you have coolant in it???)
Offline dilbert
« Reply #6 on: 24 December 2011, 17:01 »
Sounds like a thermostat mate. Worth a try only 6quid from s.c motor factors.
mk4 golf 1.8 gti 20v
Offline javalin
« Reply #7 on: 24 December 2011, 17:07 »
not the thermostat.
Offline dilbert
« Reply #8 on: 24 December 2011, 17:13 »
not the thermostat.
Stat can cause car to overheat and under heat taking ages to get heater hot
Offline javalin
« Reply #9 on: 24 December 2011, 19:07 »
but some heat would come into the cabin - particularly when stationary.
