Author Topic: lower breather pipe (PCV pipework)  (Read 1536 times)
Offline jamie1989
« on: 21 December 2011, 20:24 »
Does anyone know the part number on the above?
Its a 90degree plastic pipe which is under the inlet mani and connects the to the pcv system.
Mine is leaking oil but I think there should be an O ring seal which seals the pipe to the block am I right? There is also a 'C' locking clip which keeps the plastic pipe connected to the block, Does anyone know how far this should be pushed in as mine has quite a gap.
Finnaly I think this is my boost leak iv been looking for lol
1.6-1.8t AGU K03s, Forge actuator, Forge 007p, turbo back exhuast, Ths front mount, Catch can, 5 piece silicone boost pipes and creation sports tip. Stage 2 atm 232bhp 270lbs. Waiting for custom mapping :-)
Offline T_J_G
Re: lower breather pipe (PCV pipework)
« Reply #1 on: 21 December 2011, 20:59 »
There should be a o ring and the c clip. I bought a new one but no longer have any receipts with part number on.
Offline jamie1989
« Reply #2 on: 21 December 2011, 21:17 »
This wud cause a boost leak if leaking wudnt it?
Well I will have to remove it all and replace what evers fooked.
Im sick of only having 12psi max boost  :angry:
R-tech spec 1 should be spiking upto 18psi!
Offline paulhgti
  • GOLF 1.8T AUM 209bhp 228LB FT TORQUE
« Reply #3 on: 21 December 2011, 21:52 »
I have got to do this pipework on mine.just going to put silicone hoses on it they look a bit more hard core haha
AUM 209 BHP R-TECH STAGE 1 RE MAP,MILTEK CAT BACK 4MOTION EXHAUST,4MOTION VALANCES,PIPERCROSS FILTER,TINTS,WIND DEFLECTORS,BOOST LEAK,SANTA MONICA ALLOYS,35mm H&R LOWERING SPRINGS
Offline navmk4gti
« Reply #4 on: 21 December 2011, 23:16 »
can you get silicone hose for the pipe mentioned in the thread  :undecided:
Offline cullygti
« Reply #5 on: 21 December 2011, 23:55 »
No u can't as the one he needs is solid plastic as I need the same one a part number would be handy  :grin:
Offline paulhgti
« Reply #6 on: 21 December 2011, 23:56 »
Im probably thinking of the one that normaly splits right underneath lower breather hose
Offline cullygti
« Reply #7 on: 22 December 2011, 00:00 »
Yes mate the one that goes into the block is plastic
Offline cullygti
« Reply #8 on: 22 December 2011, 00:03 »
And some of the others coming off it can be changed for silicone when adding a catch can sorry fone playing up thus 2 posts lol
Offline Jonnybbad
« Reply #9 on: 22 December 2011, 05:18 »
The best thing to do is junk it and install a catch can the said pipe work are prone to leaking in some shape or form
