Author Topic: Grinding noise..  (Read 3637 times)
Offline Pongo
Grinding noise..
« on: 19 December 2011, 13:30 »
Hi All,  Looking for some advice on a developing noise. Best way I can describe it is a rubbing/grinding/rattle as I turn left under power, sounds to be coming from directly infront, but low, of the driver. I changed the CV joint at the weekend but this hasn't resolved it. My dad (a mechanic) fears it may be the gearbox or diff bearings?! This sounds like a pain in the asse and expensive. Anyone have other ideas I could pursue first?
Oh and its an '88 gti 8v 147K
Thanks
Matt
Offline The Mighty Elvi
  • I'm better than you today.
Re: Grinding noise..
« Reply #1 on: 19 December 2011, 13:53 »
Which side did you change, and did you grease it?
Have you checked your wheel bearings?
Offline Pongo
« Reply #2 on: 19 December 2011, 13:56 »
Thanks for replying..
I've now changed both CV joints. Haven't looked at wheel bearings.. It only happens when turning left, wouldn't wheel bearings be more of a constant noise?
Offline jezza16v
« Reply #3 on: 19 December 2011, 13:59 »
The rear engine mount is down there. It may be past its best if still the original. This can go metal to metal under sideways forces, worth a look at least.
Offline sparkplug
« Reply #4 on: 19 December 2011, 20:38 »
 i take it you changed both outside CV joints ?
have you checked the inner ones ?
or try jacking up one side at a time then spin it by hand to see if you can locate the sound
move the wheel through the turning arc too
« Last Edit: 19 December 2011, 20:43 by totalnuttah »
1986 GTI atlas grey
Offline Pongo
« Reply #5 on: 20 December 2011, 10:05 »
Yeah I've changed both outer CV joints. How do I go about checking inner ones?
Offline Sam
  • Sam I am
« Reply #6 on: 20 December 2011, 15:56 »
Get under there and have a check for splits on the boots. I also assume you absolutely rammed the new cvs with molly grease?
Offline Pongo
« Reply #7 on: 20 December 2011, 16:09 »
Yeah, absolutely ramma dam dammed them with the stuff. I replaced both outer CV's (and boots) in an attempt to cure the noise. It was there before I replaced them.
Offline Sam
  • Sam I am
« Reply #8 on: 20 December 2011, 17:05 »
Did you check the inners for splits too?  :smiley:
Offline ians
« Reply #9 on: 26 December 2011, 08:56 »
my rear inner wheel bearing needs replacing it goes quiet when turning into corners on the opposite side
