Author Topic: MK3 1.8T  (Read 72934 times)
Offline murraymint
Re: MK3 1.8T
« Reply #140 on: 21 February 2012, 17:53 »
How long did that take seanl? Could that be done ina weekend?
josh
Offline Seanl
Re: MK3 1.8T
« Reply #141 on: 21 February 2012, 18:24 »
If you dedicate all w.end then should be easily achievable. I did everything when changing the lump though. (Cambelt, clutch, crank sensor, gaskets, water pump etc etc), and had it off the road for a while. The painting of the bay did take me a while as well though tbh, but that was because I left all the loom, Brake servo, subframe etc in place, I had to be careful and mask it all, and go over it a fair few times (dark to light colour obviously). Dont see why you couldnt have it done in a day.  :smiley:
Offline murraymint
Re: MK3 1.8T
« Reply #142 on: 21 February 2012, 19:02 »
That's starting to sound like a plan  :rolleyes:. But maybe for the summer as I'm driving mine daily and would just get covered in sh!te again. Watch this space....
josh
Offline Ferdinor
Re: MK3 1.8T
« Reply #143 on: 24 February 2012, 19:05 »
Hi guys i havnt got any pictures of updates but i have got a question, the brake servo that bolts on inside the bulkhead behind the pedals, now i have removed the bolts after much struggerling, but how do i release the shaft that goes into the pedal? as im now stuck on that bit? abyone know how that comes out? i know someone said it clips out but icant even see where the clip is?  :undecided:
Any help will be great and an update will be coming over the weekend  :wink:
Offline lemski
  • 16v
Re: MK3 1.8T
« Reply #144 on: 24 February 2012, 20:01 »
Get a light in there you cant miss itbuddy
Offline DanChave
Re: MK3 1.8T
« Reply #145 on: 26 February 2012, 17:15 »
Great work on this so far mate, the rocker cover and inlet look the dogs in white!
Offline Gti_Jamo
  • 1991 Corrado 1.8 G60
Re: MK3 1.8T
« Reply #146 on: 26 February 2012, 17:38 »
I recently done this and there is a white clip that ges intio the back of the pedal with the ball ended shaft of the servo clicking into that. Just yank it hard but will more than likely break and you will need a new one. Around £4 from the dealers part number 1H 272 1169.
Also this is my engine bay before and after....
From this....
To this....
Offline murraymint
Re: MK3 1.8T
« Reply #147 on: 26 February 2012, 17:47 »
That some top work there!!!! Very nice  :cool:
josh
Offline Ferdinor
Re: MK3 1.8T
« Reply #148 on: 28 February 2012, 17:28 »
That looks really good mate, what colour is the car? I really want to do mine white but I think it might be a bit to much white? But after seeing that I'm not sure now aha
That's for the advice about the brake servo I have now got it out did what you said I broke the clip but it's out! Aha so thank you
I will be updating this soon as I have got some more work done but I'm at work ATM so I can't post any photos :)
Thank you mate, I'm really happy with how they came out :)
Offline Gti_Jamo
Re: MK3 1.8T
« Reply #149 on: 28 February 2012, 18:29 »
Its vw alpine white mate, only done the bay, wheel wells and floor and still got the rest of the car to paint in the coming weeks. Took me about 6 weeks just to get it like that but that was including painting the engine and everything else. Its all in my build thread in my sig.
Refitting the new servo clip is a bit fiddly. A good thing to remember that if your looking at the back of the pedal through the hole in the bulkhead for the servo there is a wee pin of metal pointing downwards, thats part of the pedal spring and needs to be positioned over the clip as if its left behind it the clip won't locate correctly and will also be left with some free play in the pedal. I went through two clips before I relised this. You will know what I mean when you get round to doing it.
