Hi,
So, I was driving along fine then there was a sort of whoosh noise like air dumping. After that the car ran awful (no boost, juddery, rough running) and you could tell it was about to die so pulled over....
The car turns over (slowly) and then starts, you can give it some revs when it's started but runs awful, pops and backfires a little, quite 'juddery' too, after about 10 secs the revs then drop and the car dies!
What do you think could be the issue? Had a quick look over and everything 'seems normal', it's an agu, couldn't be the ignition amp again could it? It at least ran when it went before!
Car electrics power up ok too....
Thanks in advance.... F&
*ng car!!!!
