Author Topic: Running 2 amps at different frequencies  (Read 2468 times)
Offline Adezmk3
« on: 12 December 2011, 23:44 »
Hi
Basically I am sure my headunit isn't compatible for these and what I want to know is the term for a head unit that is.
I have a low frequency amp for my subs in the boot, and want to amp my front door speakers, these need a high frequency amp, the headunit does have two outs, but only the option of either low or high frequency output across both.
What sort of headunit do I need?
Thanks
Adrian
Offline Li-D
Re: Running 2 amps at different frequencies
« Reply #1 on: 16 December 2011, 09:15 »
I think you should be able to run both just set the switch on your front speaker amp to high if possible. If not you will have to buy a high frquency made for amping loud speakers as there called :tongue:
Mk3 Golf TDI - GTD replica in progress....
OEM CHIPPED....
NO POKE WITHOUT SMOKE!
