Author Topic: sh!t-shaped utility motoring  (Read 187511 times)
Offline Bellend
Re: sh!t-shaped utility motoring
« Reply #310 on: 21 January 2013, 23:11 »
Does it have an aftermarket alarm?
Try taking the drivers door switch off and see if it stops it.
Where all my moneys went.
Offline Diamond Hell
  • Opinions я Us
« Reply #311 on: 21 January 2013, 23:43 »
No it doesn't.
Drivers door would be a reasonable starting point, but it's odd that the light comes on after I've left the car, rather than doesn't go out - I've done the 'stand and wait for the courtesy delay' thing and the f*cker goes off.  It then comes back on 'later' - whenever that is.
Offline Bellend
« Reply #312 on: 22 January 2013, 09:38 »
Girlfriends Ka would do it. Pulled the door switch and it stopped. Replaced it and it didn't happen again. No idea if it's condensation or anything like that but couldn't see anything wrong with it myself.
Other than being Ford.
Offline SoundillusioN
« Reply #313 on: 22 January 2013, 11:06 »
Anyone know if the 256mm solid disc set up uses the same hubs as the vented 256mm one?
As far I can remember from past work on mine (which is running Corrado G60 Calipers, mk2 16v vented discs and pads)  The only difference is the thickness of the disc, so if you swap out for vented, you will need to change your pads for those intended for vented.  I think there is 8mm difference between the two discs.
Edited because I got the maths wrong.  :grin:
« Last Edit: 22 January 2013, 14:51 by SoundillusioN »
Offline weazgti
« Reply #314 on: 22 January 2013, 14:30 »
I had Mk3 gti with the interior light fault. I changed it for another one and it worked fine, must of been the delay in the light gone wrong.
  • Opinions я Us
« Reply #315 on: 22 January 2013, 22:28 »
Changing the car probably will resolve the fault with the interior light, but it's a bit drastic!  :grin:
Offline weazgti
« Reply #316 on: 23 January 2013, 08:22 »
 :grin:
  • Opinions я Us
« Reply #317 on: 15 February 2013, 15:49 »
There is a reason I tend not to lower cars:
 :grin:
Offline JC
  • Back in the North.
« Reply #318 on: 15 February 2013, 18:50 »
 crazy fool  :laugh:
Offline Dave_IOW
« Reply #319 on: 15 February 2013, 18:55 »
Looks like one of the Islands better roads  :rolleyes: :sad:
Project: Mk2 20vT trackslag
Daily: Mk2 GTI typ19
