Author Topic: sh!t-shaped utility motoring  (Read 187318 times)
Offline Diamond Hell
  • Opinions я Us
Re: sh!t-shaped utility motoring
« Reply #320 on: 15 February 2013, 21:23 »
Took a bit of work to get it down to the farm after that, but I managed it.  Damn those castellations in the middle of the track.
Offline stow1985
  • 'when im cleaning winders'
« Reply #321 on: 16 February 2013, 21:10 »
I've got a road like that nr me, in london of all places I'l have to get a picture next time im working down there
  • Opinions я Us
« Reply #322 on: 17 February 2013, 10:11 »
Oh I don't think so.
Got a call from Mother later 'how on earth did you get your Golf through that track?!'
  • Opinions я Us
« Reply #323 on: 22 February 2013, 00:14 »
New front discs and pads on the front tonight.
Outer pads were *just* getting down to the metal, so I'm thinking the timing was just right.  :grin:
Obviously, I say 'new' - they're new to this Golf.  Turns out the hubs are the same on the 256mm solids as the 256mm vented and 280mm brakes.  Original carriers from the Corrado along with the discs and pads bolted up, once the pistons had been wound back, probably further than they ever had been.
Bit of surface rust needs scrubbing off the discs and then I'm sure they'll bed in well.... although they're Green Stuff pads.  I recall them being a bit sh*t on the Corrado, so probably won't be much better now.  At least they have less enthusiasm to contain this time.  :grin:
  • Opinions я Us
« Reply #324 on: 22 February 2013, 13:36 »
The only bit that had to be swapped to allow the vented rotors to go on, BTW:
Just has a wider gap for the rotor and that's it.
Offline JC
  • Back in the North.
« Reply #325 on: 22 February 2013, 18:31 »
got another set lying around  :whistle:
Offline Dave_IOW
« Reply #326 on: 22 February 2013, 18:35 »
Think the mk3 might become redundant soon, so you might be in luck :grin:
Project: Mk2 20vT trackslag
Daily: Mk2 GTI typ19
Offline JC
« Reply #327 on: 22 February 2013, 18:47 »
 :laugh:
  • Opinions я Us
« Reply #328 on: 22 February 2013, 19:10 »
You need a set of hubs and there's a pair of 280mm carriers with calipers available.  :kiss:
  • Opinions я Us
« Reply #329 on: 18 April 2013, 23:56 »
While I haven't welded up the hole in the sill I did give it a birthday tonight and changed the oil, oil filter and air filter.
Average fuel consumption had fallen to about 48MPG, so let's see if this brings it back up around 50MPG again.
Needs new boots before too long as well.
Nearly ticked over 180k too.
