Author Topic: audi 3A engine  (Read 3418 times)
Offline jamiecoysh
audi 3A engine
« on: 05 December 2011, 23:49 »
hi all i have a 1989 2.0 8v audi 80 with the 3A engine and im having a problem where every now and then when i pull up at lights or sometimes im heading downhill in for example 4th gear with my foot off the gas and i dip the clutch like pull up at lights and the idle will be 1000 rpm, when its normally about 750. If i leave it and continue driving the engine becomes really snatchy when taking my foot off the gas to slow down. \if i switch it off and back on again its fine untill the next time. I recently changed the isv and when it did this problem with replacement isv, insted of idle being at 1000 steady, it would rev up and down fast between 900 and 1300 rpm when it started to play up.
just wondered if anyone has come across this prob maybe with the equivilent golf engine
cheers
Offline The Mighty Elvi
  • I'm better than you today.
Re: audi 3A engine
« Reply #1 on: 06 December 2011, 00:04 »
Oh...where to start..
 :lipsrsealed:
Re: audi 3A engine
« Reply #2 on: 06 December 2011, 00:06 »
Try asking in an Audi forum...
 :kiss:
Offline AudiA8Quattro
Re: audi 3A engine
« Reply #3 on: 06 December 2011, 00:23 »
What is injection system is fitted?
Offline X4MGS
  • VAG Parts SNOB!!!
Re: audi 3A engine
« Reply #4 on: 06 December 2011, 00:24 »
Try the S2 Forum; http://www.s2forum.com/
My S2 Had a similar issue and I replaced the MFTS (Multi Function Temp Sender) And cleaned all the contacts on the MAF & doused it in WD40... Just an Idea...
For More Info Click To See;
Offline clipperjay
Re: audi 3A engine
« Reply #5 on: 06 December 2011, 09:14 »
Does it have a micro switch on the TB if it does check it if it clicks okay?
Offline Diamond Hell
  • Opinions я Us
Re: audi 3A engine
« Reply #6 on: 06 December 2011, 09:58 »
This and also IIRC there may well be an idle adjustment screw on the throttlebody.  This may have been wound up to compensate for a knackered ISV.
You also need to check all the inlet pipes for vacuum leaks - an unlit blowtorch is your friend - take it up and down the pipes slowly (outside is probably best  :wink:).  If you find a vacuum leak, the engine will race on the gas.
Re: audi 3A engine
« Reply #7 on: 06 December 2011, 18:01 »
+2 to the microswitch. I had this problem on a passat 2.0 16v with the 9A lump, it wouldn't idle, when i restarted all was fine, a new switch cured the problem.
Offline jamiecoysh
Re: audi 3A engine
« Reply #8 on: 08 December 2011, 23:03 »
hi all thanks for your replies
ill try and answer all the replies that have been listed 1stly ive already tried the audi forums but havent had much luck with them. the injection system is the type that uses the metering head ( think its a cis or something lol ) its the golf 2.0 8v gti engine effectivly just mounted round the wrong way lol. I was advised against playing with the idle air screw by the garage i use as the engine runs spot on and say hyperthically it was to cure this problem could strt a new set of running problems. I was leaning towards the idle switch myself. Does any one have any links to or pics of what it looks like and is it available to buy new or is it a new throttle body. Cheers
Offline jamiecoysh
Re: audi 3A engine
« Reply #9 on: 08 December 2011, 23:21 »
this is a link to the throttle body that it uses
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=280786157299&fromMakeTrack=true&ssPageName=VIP:watchlink:top:en
can i buy just the switch new (and where from) if it uses one!
and are they hard to fit?
