Author Topic: audi 3A engine  (Read 3416 times)
Offline clipperjay
Re: audi 3A engine
« Reply #10 on: 08 December 2011, 23:28 »
The throttle cable if you pull it to rev you will see the end of a cylindrical pully that the throttle wire sits around. If you look at the rest point of that it hits a tiny micro switch which is about 2cm Long and 1cm wide it will either have a black rubber dot or a red rubber dot where the throttle activates this switch from rest to load or open & closed postions. There it should be mounted via one or two screws most peeps just push against the rubber cover to hear if it clicks, but if you have a multi meter you cna test the circuit if there is continuity in an open or closed position.
Not sure if you cna just buy the switch I tried many times its sometimes moulded onto the throttle body itself and you have to drill it out just to fit a new one on. In the end I just took one off a whole throttle body!
Offline nrm69
Re: audi 3A engine
« Reply #11 on: 09 December 2011, 21:12 »
What is injection system is fitted?
Bosch Motronic
Offline Diamond Hell
  • Opinions я Us
Re: audi 3A engine
« Reply #12 on: 09 December 2011, 23:34 »
Bosch Motronic
No, it's either K-Jet, or KE-Jet.
Offline nrm69
Re: audi 3A engine
« Reply #13 on: 10 December 2011, 14:04 »
Bosch Motronic
Apologies-I'll stand corrected. For some reason I have a Bosch Motronic book that I bought when I had an Audi 80 Sport with 3A engine but it does look like it would have had KE-Jetronic.
Offline Sam
  • Sam I am
Re: audi 3A engine
« Reply #14 on: 11 December 2011, 19:00 »
Bosch Motronic
I dont think we are going to get anywhere with this anytime soon  :rolleyes:
