Author Topic: Got cold now cars steamed up?  (Read 2972 times)
Offline emery1990
« on: 05 December 2011, 21:24 »
I'm guessing if this happens in the cold then it is a seal that is leaking? Or do cars generally steam up in the colder weather, never steamed up once in the summer months even when poured down.
Offline Sam
  • Sam I am
Re: Got cold now cars steamed up?
« Reply #1 on: 05 December 2011, 21:39 »
They're all twits for steaming up in the winter, not alot you can do other than a big bag of silicon gel somwhere in the car. I would suggest two, so you always have a dry one  :smiley:
Offline emery1990
« Reply #2 on: 05 December 2011, 21:41 »
lol yer done that last winter, bought 200 silicone gel packets, guess i'll do same this year! can't be good for me leathers the moisture in there!
Offline The Mighty Elvi
  • I'm better than you today.
« Reply #3 on: 05 December 2011, 21:59 »
Water / moisture inside the car.
As it cools it condenses on the inside of glass.
Offline emery1990
« Reply #4 on: 05 December 2011, 22:27 »
Yer but would of thought it would do it in the summer still as thought the glass would still be coldish.
« Reply #5 on: 05 December 2011, 22:35 »
Not necessarily as the ambient temperature is higher.
If you had sh!t loads of water in the car in the summer, then yes, you would have a sauna like experience, e.g steam
In Winter, the inside of the car is warmer than the outside. Any moisture in the car that hits the cold glass condenses.
It's not broken seals letting air in, its damp air already inside the car.
Offline emery1990
« Reply #6 on: 05 December 2011, 22:56 »
Ahh least I wont need to change them then!
« Reply #7 on: 05 December 2011, 23:21 »
No.  Lift up all the carpet in the footwell.  Mop up any moisture.  Then you can grease over the throttle and bonnet release cable grommets in the scuttle tray.  Seal the Air blower mesh cover seal.  Generally seal up any possible entry point for rain water.  Also the rear lights can let in water into the boot as their foam surrounds can perish.
This, when inside the car causes the "steaming up".
Silica bags help, but a good blast with windows and sunroof open do much better.
Offline pigbladder
« Reply #8 on: 06 December 2011, 08:23 »
they do steam up a bit more than modern cars with a/c but if its constantly soaked theres prob a leak somewhere
one tip that helps ...near the end of each trip turn off the heat and drop the windows , having the interior same temp as outside helps it a bit
any leave a window /roof open whenever you can if its fry out
Offline clipperjay
« Reply #9 on: 06 December 2011, 09:13 »
Its simples condensation forms when two sides have a shift in temperature one side is usually cold the other hot.
The only way to stop this is to put double glazing in the Golf.
Okay joking like everyone else has said if you have less contact with cold the cold side the less it will form. Insulation and trying to match outside temps inside like letting heated air from the car out before you get out!
Otherwise you might need to check if the blower as this blower helps to clean the screen of condensation quicker by warming up the glass to fight the temperature shift from outside!
