Author Topic: XP Pro to Home Edition  (Read 1918 times)
Offline R32UK
« on: 01 December 2011, 11:47 »
Have old PC i havent used for ages and have now found some use for it. It was originally shipped with Windows XP Home Edition. As I used this at uni I needed XP Pro, so I did what I my other student buddies did and instaled it from a *cough* friends disk *cough*.
Now that I have switched it on after many moons it states that the copy of XP Pro is not genuine. The base unit has a sticker on with the key for the original HE it shipped with. Is it possible to go from Pro back to HE as I dont want to be running a dodge copy.
tia
 :smiley:
Offline clipperjay
Re: XP Pro to Home Edition
« Reply #1 on: 01 December 2011, 11:51 »
Go to registry and delete GWA or and use the doggy search to find the files then remove all is good afterwards apparently! They are smart it will be a K no. file  :wink:
Disclaimer: any mucking about with regedit will or can lose functionality don’t PM about it  :lipsrsealed:
Offline R32UK
« Reply #2 on: 01 December 2011, 12:15 »
despite having a degree in computer science.. that sounds a little complicated to me  :grin:
may leave it to the professionals! :smiley:
unless their is an easier way  :undecided:
Offline Ridg
  • TDI - Soot Happens!
Offline Organisys
  • Old and Slow...
« Reply #4 on: 01 December 2011, 12:40 »
sheesh, google 'remove windows genuine advantage'
then don't install or run anything which will first test to see if you are running gen windows.
Offline DubFan
« Reply #5 on: 01 December 2011, 16:44 »
Or find a genuine XP Pro serial key (one that matches the version you installed off the CD) and then use a Windows XP Pro keychanger to change your windows key.
Then it will think it's a genuine copy of XP Pro and will let you do anything.
Offline Dolly
« Reply #6 on: 01 December 2011, 19:05 »
probably easier to download xp home edition and use the original product key. its very easy to get hold on, stick it on a disc and away you go. find one with service pack 2 or 3 to save the million updates youll get,
im sure i used to have xp on floppys  :laugh:
Offline R32UK
« Reply #7 on: 01 December 2011, 19:46 »
Ok guys thanks for the help!
 :cool:
Offline Wazzzer
  • Golf GTI 1.8T AGU
« Reply #8 on: 01 December 2011, 22:25 »
Would you like a corporate key for XP Pro?
Offline Guy
« Reply #9 on: 02 December 2011, 14:26 »
can you not upgrade to 7?
