Author Topic: Sidelight Help  (Read 3362 times)
Offline big_el
Sidelight Help
« on: 01 December 2011, 08:01 »
Hi ,
Just wondering if anyone has a clue what is going on lol. Decided to get rid of my candle sticks at the front. Ive changed the sidelights for LED ones and i know because of the polarity they have to go in a certain way but when they are in the right way they come on for about 10 secs then turn off !
Any ideas ? Thanks
Offline big_el
Re: Sidelight Help
« Reply #1 on: 02 December 2011, 09:34 »
Anyone ?
 :undecided:
Offline AlanD
  • MK5 2.0T 16v
Re: Sidelight Help
« Reply #2 on: 02 December 2011, 11:18 »
Yep, the LED lights you have installed do not have an inbuilt resistor. Due to the nature of how LEDs work they draw less current when running. The ECU detects there is less current draw and assumes that the bulb is faulty and turns it off. This is my guess. Where did you get your LEDs from? I bought mine from eBay from this seller - http://myworld.ebay.com/ibid-uk/
They work a treat and are a million times better than the "Phillips BlueVision" ones I had previously upgraded to. LED lights are the way forward.
Offline big_el
Re: Sidelight Help
« Reply #3 on: 02 December 2011, 14:34 »
I bought item number
250938256449
Only because it had 5 leds on each one so thought they would be better. I seen them ones, so you think i should get them ?
Thanks
Offline AlanD
  • MK5 2.0T 16v
Re: Sidelight Help
« Reply #4 on: 03 December 2011, 00:10 »
From you describe it sounds like they dont have a resistor or it isnt working properly. They work fine on mine so can only suggest you get them. If you get them and they work I would be having words with the person that sold you the originals and try and get your money back.
Offline Harris GT TDi
Re: Sidelight Help
« Reply #5 on: 04 December 2011, 00:59 »
250938256449
Thanks
Hey mate,
From what you have described I have been through the exact same thing.
I bought a set like yourself without an inbuilt resistor, looked good but went off all but straight away.
I then bought a set with inbuilt resistors from Mr LED's on ebay.
They work and look awesome now and I have bought a full LED conversion through him for in the car and number plates LED's and all work perfectly and look far more modern.
Hope this helps.
Golf GT Tdi!
New Style 18" RS4 Alloys, Eibach -30mm Pro Kit Lowering Springs, New Style Black GT Lights with H7 Anti Glare Xenon's, Colour Coded Lower Rear Bumper, Full LED Bulb Conversion Throughout,
To come, re -map!!!! :)
Offline crimsonfin
Re: Sidelight Help
« Reply #6 on: 05 December 2011, 11:52 »
are these uk legal and would they pass an MOT ?
Offline AlanD
  • MK5 2.0T 16v
Re: Sidelight Help
« Reply #7 on: 05 December 2011, 12:55 »
Yes and yes :)
Offline big_el
Re: Sidelight Help
« Reply #8 on: 06 December 2011, 22:01 »
i bought some resistor ones and the work and look awesome. i forked out for bright white h7s and they both look odd now because the leds look amazing, so ive got blue/white and pure white :-s
Offline crimsonfin
Re: Sidelight Help
« Reply #9 on: 07 December 2011, 08:37 »
are sidelights the only replacement LED bulbs you can (legally) put in your car.  Ideally i would want to replace all of :
  • dipped beam
  • main beam
  • front fogs
