Author Topic: Driving Lights - Spot Lamps  (Read 3867 times)
Offline shaolindan
« on: 28 November 2011, 16:44 »
I've got an almost new set of the inner spots (with the blue Hella logo in the middle) to replace my original ones that have now gone cloudy.
Using the search function on the forum, it has been said that the old 'clips' tend to break when you take the old lights out. However VW don't sell them anymore, nor do GSF or VW Classic (from VWHeritage).
I believe that I want "Mounting Parts for driving lights in radiator grill - VW191998135A" - as I say all the obvious places can't source them. On ebay I have found http://www.ebay.co.uk/itm/Head-lamp-light-lights-Adjusting-clips-VW-Golf-MK2-set-3-/260877091962?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item3cbd7c847a#ht_1045wt_1095 - I'm reasonably certain they will work with the inner spots - can anyone confirm this?
Or would http://www.ebay.co.uk/itm/GOLF-MK2-GTI-G60-SYCRO-HEADLAMP-ADJUSTER-CLIPS-GENUINE-/350493890348?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item519b10572c#ht_1547wt_862 be enough?
Golf GTi 8v mk2 1990
Coilovers, BBS RA, K&N Induction Kit...
Offline X4MGS
  • VAG Parts SNOB!!!
Re: Driving Lights - Spot Lamps
« Reply #1 on: 28 November 2011, 17:34 »
Headlamp clips are different to spot light ones... The Europarts ones look like spotlight but I guess when they arrive they wont fit...
The old ones are easy(Ish) to take off... douse them in WD40 and have a couple of sets of pliers handy... A really small one helps but if you are JUST fitting new lamps you wont need to take the black parts out of the grille, it just a matter of CAREFULLY twisting the White clips at the rear....
Hope this makes sense...
For More Info Click To See;
Offline Thom89
  • Looking for an "Icebreaker"
« Reply #2 on: 28 November 2011, 17:58 »
As above, also try warming the clips to make them a little more flexible before removing...
Also consider that lamps that have gone cloudy, and dull, can be brought back to life by submerging them in a strong bleach and hot water mix, and leaving them for half a day, you wont believe they are the same lamp!
Thom
Offline clipperjay
« Reply #3 on: 28 November 2011, 18:01 »
I've used the rice method also seems to absorb the dirt.
Offline Thom89
« Reply #4 on: 28 November 2011, 18:03 »
Was that boiled or stir fried Jay?
Thom
Offline mk2bal
« Reply #5 on: 28 November 2011, 18:11 »
Egg fried only
Offline shaolindan
« Reply #6 on: 28 November 2011, 19:02 »
Cool. I shall try that. I did get them from you after all....  :laugh:
Offline clipperjay
« Reply #7 on: 28 November 2011, 19:51 »
Thom
Listen pop any broken ECU in the freezer it will fix it self right away!
http://www.wikihow.com/Clean-a-Bong  :grin:
Offline shaolindan
« Reply #8 on: 29 November 2011, 11:00 »
Thom
Yeah, I know that can have quite an effect. But I got them from X4MGS who had it at a good price - which I was prepared to pay for the Hella logos in the middle!
Offline Lewy
« Reply #9 on: 29 November 2011, 11:15 »
Haha, Hella logo's are about 20p each and they weren't fitted to GTi spotlamps, only Driver and Ryder.
