Author Topic: home ethernet  (Read 3947 times)
Offline Guy
home ethernet
« on: 28 November 2011, 12:14 »
word up
popping in the new sky bb router at the mrs' home at some point in the next couple of days
want to also upgrade their sky box to HD+ anytime which means we can download movies/boxsets/series etc on demand
now... had the thought that I would install it upstairs next to the phone point in the room where the desktop is
then... from the router in this location run an ethernet cable to the wall and directly down to the point where the tv box is... obviously I would want to run it to boxes so I could unclip the cables and walk away as necessary and just leave the junction boxes
so
phone point upstairs -----> router ------> desktop
                                      wall box
                                      wall box downstairs  -------> sky box
landline phone on separate phone junction downstairs with ADSL filter
so... what tools, equipment etc do I need to do this and what should I be aware of when going through cavity walling?
Offline Ridg
  • TDI - Soot Happens!
Re: home ethernet
« Reply #1 on: 28 November 2011, 14:35 »
you need two face plates, a lenght of network cable, the type you get will dictate the maximum speed (achievable), cat5 is 10/100, cat5e/cat6 is 10/100/1000.
regarding the fitting, no different than routing an cable, if you're doing a proper job then you'll want chase out a channel for the cable then plaster over it.  If you're doing a bodge job then you could simply drill trough the ceiling and leave the cable hanging, in-between this you've got tower clips (the type you would run a phone extension with).
Re the ceiling, the gap can be bigger than you think, so you're going to need either a large drill or something to feed the wire through a hole drilled either side, best bet is a sparky on the forum.
Personally as it's the sky box then I'd get a wireless acess point and a wireless router, the anytime / on demand wont be able  saturate the wireless bandwidth
phone point -----> wireless router ------> desktop
                               wi-fi
                 wireless access point or router -------> sky
you basically create a bridge between the two wifi devices which is the same as running a cable, given the cost of running a cable properly this would probably be cheaper.  an other alternative is the ethernet over power, this uses your home wiring as the cable.
also given the main problem you've got here is routing cables, I'd probably say off topic would be a better place (maybe).
Offline Guy
Re: home ethernet
« Reply #2 on: 28 November 2011, 14:58 »
(i thought as it was talking bout tech stuff it might be better off in the tech sectchun - there would be crossover whatever section it went in :/)
i was thinking as the walls are that silly plasterboard stuff that I could just drill a hole in it and drop a cable down the gap in the wall :/
you can pickup a sky specific wireless receiver for £60 which would probably be the best solution but I kinda liked the idea of paying about a tenner for the whole solution
I was just thinking would I need crimps or anything for connecting up the junction boxes?
Offline Dolly
Re: home ethernet
« Reply #3 on: 28 November 2011, 16:01 »
you need 2 faceplates and 2 RJ45 outlets
so two of these (as they include the lot)
http://www.screwfix.com/p/philex-rj45-module-outlet-kit-single-cat-5e/10030
stick one behind the tele and one near the router, get the length of cable and its a scotch style fit into the back of the connectors, instructions show you what colour wire for what pin but its easy enough, just a small blunt screwdriver to push the wiring into the connectors. there is a tool but ive never used one..
Offline Guy
Re: home ethernet
« Reply #4 on: 28 November 2011, 16:09 »
bonza.... do they recess back into the wall?
Offline Dolly
Re: home ethernet
« Reply #5 on: 28 November 2011, 16:21 »
those dont they sit out,
i suppoose you could use this so its flush http://www.screwfix.com/p/single-keystone-jack-faceplate/29153
but then dont forget you need the outlet http://www.screwfix.com/p/philex-rj45-cat5e-jack-punch-down-outlet-90-white/72694
you can use either 90 degree or 180 degree connectors with most faceplates. the connectors just clip into the faceplate
Offline Guy
Re: home ethernet
« Reply #6 on: 28 November 2011, 16:37 »
i was hoping they would as I was looking at the double kit for the unit you recommended... if you look at the second review there is a photo
http://www.screwfix.com/p/philex-rj45-cat5e-module-outlet-kit-double/34584#
i am guessing that it is just like the two separate products you recommended plus this http://www.screwfix.com/p/45mm-1g-network-pattress/10228
i'll get the two double kits + some cat5e (maybe some cat 6) cable
what tool/s would you recommend for stripping the wires and punching down... i don't mind buying tools if I am saving money, chances are if this install works I will get carried away with it and install data everywhere  :evil:
Offline Dolly
Re: home ethernet
« Reply #7 on: 28 November 2011, 16:44 »
you only need to strip back the outer cables to expose the 8 wires inside, you do not need to strip the 8 small wires, they just push in. like i say scotch like style, i cant vouch for tools i use a small screw driver but something like this
http://www.ebay.co.uk/itm/RJ45-RJ11-Cat5e-Network-Cable-Punch-Down-Impact-Tool-UK-/250652856235?pt=UK_Computing_NetworkingTools_Accessories_SM&hash=item3a5c130fab#ht_2797wt_1089
Offline Dolly
Re: home ethernet
« Reply #8 on: 28 November 2011, 16:49 »
if you use a double box you can dispose of the single phone line box.
so you have the phone in coming in the left socket and then the one to downstairs going to the right socket. save having 2 seperate boxes. you can plug adsl/phone lines into rj45 connectors.
i know this as in my brothers house,  i used 2 rj45 connectors and cat5 cable to effectively extend the phone line into his sky router as he didnt want the router in the hall by the front door where the phone line box is.
Offline Guy
Re: home ethernet
« Reply #9 on: 28 November 2011, 16:51 »
okey dokey so some crafty work stripping it with a craft knife and then getting a cheap punch  :wink:
