Author Topic: car feels like its going to stall  (Read 5250 times)
Offline GJSEB79
« on: 27 November 2011, 19:21 »
for arguments sake if i was going round the corner in my village doing about 35 40 in fourth if i dont drop it down it feels like it would stall i always thought dervs had sh!t loads of torque an could handle this sort of driving but am i wrong never had on my petrol at all
Offline richw911
Re: car feels like its going to stall
« Reply #1 on: 28 November 2011, 09:01 »
Normal for diesel  :wink: You have to shift more as the power band is completely different to a petrol  :smiley:
Offline Rhyso
« Reply #2 on: 28 November 2011, 09:16 »
At that speed you're barely ticking over and you're loading the engine up.  Also its the quickest way to ruining your clutch.
Power band on a derv is from around 1600rpm to 2500rpm depending on the engine model.  The 150 makes its power towards 3000rpm
On mine I can do 30mph in 5th gear but that's barely pulling 1100rpm  :laugh: :laugh:
Offline GJSEB79
« Reply #3 on: 28 November 2011, 15:44 »
right i am running a 115 pd but i would have to drop it down to 2 if i was doing 30mph is this about right i thought the talk would be able to handle low down driving like this am i wrong completely then
Offline GJSEB79
« Reply #4 on: 28 November 2011, 15:44 »
torque
Offline Rhyso
« Reply #5 on: 28 November 2011, 21:12 »
2nd at 30mph is over 2000rpm iirc
What rpm are you doing in 4th gear @ 35mph?
Offline GJSEB79
« Reply #6 on: 29 November 2011, 09:14 »
from memory i would say about 1300 mate would you say this is to low  :smiley:
Offline Rhyso
« Reply #7 on: 29 November 2011, 09:48 »
far too low lol; turbo has just about begun to spool
Like I said your useful power band is from approx 1600rpm to 2500rpm; drop a gear and see if the car picks up better :afro:
Offline GJSEB79
« Reply #8 on: 29 November 2011, 10:41 »
yeh car flys when i drop it down a gear once i have had it remapped should the turbo spool up alot quicker an lower down the rev range an thanks for help rhyso
Offline Rhyso
« Reply #9 on: 29 November 2011, 12:49 »
It will be more responsive but again it will mainly fatten that power band and also hold the power a little bit longer  :smiley:
