Author Topic: Mk3 takes a bit of starting when hot  (Read 1755 times)
Offline Ninj
« on: 26 November 2011, 08:15 »
Don't think this is the normal GTi starting issue............
Starts within a second or so when cold/been stood for a bit but takes about 3/4 secs of cranking when its been run/hot.  Id say its getting slowly worse over the last few months.
Ive noticed if you quickly hit the starter, ign off and restart it fires up quicker than letting it churn away.  Never cuts out or runs badly when hot or cold for that matter, just the starting prob.
Any ideas?
I'm thinking fuel related almost as though its evaporating or airlocking somewhere and it's needing a good squirt from the pump to fire it up.  Checked the usual suspect relays and none of them are cold.  Could it be the coolant temp sensor (or do I mean ECU temp sensor!)?  Is there a way to check it?
Thanks in advance
« Last Edit: 26 November 2011, 08:25 by Ninj »
Offline harlemex
Re: Mk3 takes a bit of starting when hot
« Reply #1 on: 27 November 2011, 21:19 »
I had this issue. Never got to the bottom of it.  :sad:
Offline Seanl
« Reply #2 on: 27 November 2011, 21:40 »
Fuel pressure reg, clogged return pipe, fuel pump. :undecided: all speculation but possible
Offline javalin
« Reply #3 on: 28 November 2011, 12:28 »
coolant temperature sensor?
James
You only ever need two tools in life. If it moves and it shouldn't use Duct Tape. If it does not move and it should, use WD40.
Offline Len
« Reply #4 on: 28 November 2011, 13:01 »
Are we talking 8v or 16v here?
www.sas.org.uk
www.the-ace.org.uk
Offline Ninj
« Reply #5 on: 28 November 2011, 13:13 »
8v sorry.
I imagine a blocked/restricted fuel line would manifest itself by rough running at all rpms, not just starting when it's warm?
Coolant temp sensor is an option I suppose but the quoted symptoms don't really match mine. Might be worth a swap to rule out though.
Cheers for the suggestions guys
Offline Len
« Reply #6 on: 28 November 2011, 13:18 »
These kind of things are usually a fuel evaporation problem.
www.sas.org.uk
www.the-ace.org.uk
Offline javalin
« Reply #7 on: 28 November 2011, 13:39 »
I thought that was more of a carb problem rather than injection?  Where is it evaporating to?
Offline leegt5
« Reply #8 on: 28 November 2011, 19:23 »
Before my coil packed up it wouldn't start unless i let the car cool down and then it started.
« Reply #9 on: 28 November 2011, 23:55 »
Have you checked the compressions  :smiley:
