Author Topic: stored codes on 2.0 passat  (Read 3144 times)
Offline gttjames
« on: 25 November 2011, 13:44 »
A friend of mine at work has asked me to read his codes as his car has cut out a few times, its a 2.0 petrol 2002 passat, codes stored are
17927
 P1519
 Intake Camshaft Contr.,Bank1 Malfunction
16705
 P0321
 Ign./Distributor Eng.Speed Inp.Circ Range/Performance
16706
 P0322
 Ign./Distributor Eng.Speed Inp.Circ No Signal
Anyone shed some light, dizzy cap and rotor arm to start with?
cheers
« Last Edit: 25 November 2011, 13:51 by gttjames »
Offline daz veedub
  • Operation 1.8t bolf
Re: stored codes on 2.0 passat
« Reply #1 on: 25 November 2011, 13:54 »
17927
 P1519
16705
 P0321
16706
 P0322
cheers
17927/P1519/005401 - Camshaft Adjustment Bank 1: Malfunction
Possible Symptoms
    * Malfunction Indicator Light (MIL) ON
Possible Causes
    * Fuse(s) faulty
    * Camshaft Adjustment Valve Bank 1 (N205) faulty
    * Wiring and/or Connector(s) from/to Camshaft Adjustment Valve Bank 1 (N205) faulty
Possible Solutions
    * Check Fuse(s)
    * Check/Replace Camshaft Adjustment Valve Bank 1 (N205)
          o Perform Output Test/Basic Setting
    * Check Wiring and/or Connector(s) from/to Camshaft Adjustment Valve Bank 1 (N205)
16705/P0321/000801 - Engine Speed Sensor (G28): Implausible Signal
Possible Symptoms
    * Engine shuts off
    * Engine doesn't start
    * Speedometer inoperative
    * Glow Plug Indicator Lamp (K29) flashes
Possible Causes
    * Engine Speed Sensor (G28) loose
    * Engine Speed Sensor (G28) faulty
Possible Solutions
    * Check Engine Speed Sensor (G28)
Special Notes
    * The Engine Speed Sensor (G28) is also used as a reference sensor for the crankshaft position and correlates with the Camshaft Position Sensor Bank 1 (G40) and Camshaft Position Sensor Bank 2 (G163).
    * When found in a VW Golf/Jetta (1J/9M) or Audi A3 (8L) with 1.9l TDI-PD (AXR), check TPI 2007067 which explains issues with electro magnetic interference. A modification to the wiring will fix this problem, extensive details can be found in the named TPI. Even though this TPI was originally released for VW Golf/Jetta (1J/9M), a customer of ours came across the same issue on an Audi A3 (8L).
    * When found in a 2004 VW Golf, Jetta, or New Beetle with 1.9l TDI-PD (BEW), check for TSB 2010461 (01-07-45 formerly 97-05-03) or 201463 (01-07-44 formerly 97-05-04) calling for a flash update to the ECU and a secondary ground installation.
16706/P0322/000802 - Engine Speed Sensor (G28): No Signal
Possible Symptoms
    * Engine shuts off
Possible Causes
Possible Solutions
Special Notes
    * The Engine Speed Sensor (G28) is also used as a reference sensor for the crankshaft position.
Retrieved from "http://wiki.ross-tech.com/wiki/index.php/16706/P0322/000802"
Category: Fault Codes
