Author Topic: Bought Another GTI 8v tho :( few problems  (Read 2187 times)
Offline t0pgunner
« on: 25 November 2011, 12:24 »
hi justt bought a nice L reg plate in candy white she looks a beaut  :kiss:
few problems
temperature reads 90 on the electronic trip thing but the dash instrument only reads 70 or sometimes lower :S
If this needs replacing i have a speedo from a 97 8v golf will this work ok?
somtimes when i come upto junctions whack her into first she stalls for no reason (clutch is in etc)
any idea's
also heatshield is rattling anyone got idea's on a quick fix for it
cheers t0pgunner
Re: Bought Another GTI 8v tho :( few problems
« Reply #1 on: 25 November 2011, 12:27 »
That is oil temp so will be a higher reading than water temp.  :smiley:
Offline t0pgunner
« Reply #2 on: 25 November 2011, 12:29 »
ok but the dash reading is still under 90 where it is supposed to sit tho wayne :(
Offline MK3 Menace
  • 98 GTI, big changes are coming...
« Reply #3 on: 25 November 2011, 12:31 »
The temperature on the MAF is for the oil temp and the gauge is for water temp.
The cutting out at junctions is what mine did when I purchased it. Check all the breather hoses for splits or tears. Even a pin hole will cause it to suffocate.
Also, give the throttle body a good clean with some carb cleaner.
Have a look at the guides here, plenty about.
If you need a new breather hose, I have a few and happy to help if you are near Milton Keynes.
Offline MK3 Menace
« Reply #4 on: 25 November 2011, 12:32 »
My temp on the MAF only goes above 90 if I give it a good thrash or on a long run down the motorways. Mine sits around mid 80's normally.
Offline t0pgunner
« Reply #5 on: 25 November 2011, 12:34 »
thanks alot mate for the advice i will check the breathers at the weekend as i have alot of uni work to do. that does make sence as my old golf used to do that but not as much so is it a case of a bad gauge or what???
and i know how to clean the throttle body easy job to do just havent got the time atm  :undecided:
« Reply #6 on: 25 November 2011, 12:38 »
Temp sender, themostat or air lock I suspect.
Offline MK3 Menace
« Reply #7 on: 25 November 2011, 12:38 »
When you take the breather pipe off from the flying saucer (under box on top of rocker cover) be careful as the ends get very brittle. Same with the other end at the crankcase breather, make sure you take to clip out first before you yank at it.
When you got it off fill up a bucket or something with a good cleaner and soak it for a bit to get all the crap and gunked oil out of it. Then give it a good clean out with WD40 after and you should be able to see if anything is seeking out the sides...
Dan
Offline t0pgunner
« Reply #8 on: 25 November 2011, 12:45 »
ill get some more silicone hosing on flebay at the weekend and clean throttle body etc see how it goes
Offline javalin
« Reply #9 on: 25 November 2011, 13:30 »
get it removed, or a large jublee clip does it apparently.
goes it go to 90c if when standing still?  If it does, its the thermostat, if not its the temp sensor.
James
You only ever need two tools in life. If it moves and it shouldn't use Duct Tape. If it does not move and it should, use WD40.
