Author Topic: immobiliser  (Read 3269 times)
Offline NERF 69
immobiliser
« on: 23 November 2011, 17:40 »
Can anyone tell me where i would find the immobiliser?
Sell my Vw??? I'd rather stick wasps up my arse
Offline madmanmart
Re: immobiliser
« Reply #1 on: 23 November 2011, 18:05 »
The ECU is the imobilizer........
Mk3 Golf 3dr GTI 16v
Mk3 Golf Cabriolet TD
20vt Corrado track car project
Offline NERF 69
Re: immobiliser
« Reply #2 on: 23 November 2011, 18:07 »
Ah. I was hoping it wasnt. Thanks pal
Offline Deano2711
  • 1992 VR6
Re: immobiliser
« Reply #3 on: 23 November 2011, 20:41 »
Immobiliser box is located either behind passenger glovebox or airbag or can be found behind the clocks. Is this related to your non starting fault as the immobiliser would allow te car ti start and cut out straight away.
Offline trog_nfs
Re: immobiliser
« Reply #4 on: 23 November 2011, 20:43 »
Immobiliser box is located either behind passenger glovebox or airbag or can be found behind the clocks. Is this related to your non starting fault as the immobiliser would allow the car to start and cut out straight away.
I found this when the chip fell out of my flip key.  :smiley:
Offline NERF 69
Re: immobiliser
« Reply #5 on: 23 November 2011, 20:55 »
Surely if it faulty it could cause all sorts of problems
Offline Deano2711
  • 1992 VR6
Re: immobiliser
« Reply #6 on: 23 November 2011, 21:11 »
If it was faulty the car would start and then cut out straight away. The immobiliser does not stop the car starting but cuts out the fuel pump which is why the car won't run. To check out or remove the immobiliser you would need the car started anyway. Your fault is not immobiliser related IMO. A fellow member on here had a similar problem a while back where he sent weeks looking for the reason his car would not start. In the end he found out the ECU earth was faulty....changed this and away it went.
Re: immobiliser
« Reply #7 on: 23 November 2011, 21:20 »
Unless it is an early one in which case they did not have factory fitted units.
Offline NERF 69
Re: immobiliser
« Reply #8 on: 23 November 2011, 21:25 »
Mine is a 95 model not sure if its too old. Where is the ecu earth? Ive got the ecu off now and i havent come across an earth yet
Offline Deano2711
  • 1992 VR6
Re: immobiliser
« Reply #9 on: 24 November 2011, 08:05 »
Not sure Bud....PM a member on here called VDubNinja. He had the problem and can tell you exactly what he did. Hope this helps      Cheers
